Problem. Fast refresh mode stay always activated....
Postby jon.191023 » Tue Feb 13, 2024 1:49 am
I don't understand but since these last days after i Resized pictures on my profil. The fast Refresh mode activated himself on my LAN without action on my side.
I tried to force normal mode from server side but it doesn't change anything...
From my GoverlayPlus app :
From my server side account configuration
Do you have an explanation about it ?
I Would like to turn off that mode in order to reduce stress on CPU hardware calls.
jon.191023
Re: Problem. Fast refresh mode stay always activated....
Postby TheLaGmAn » Tue Feb 13, 2024 1:45 pm
Fast refresh mode will deactivate itself 30 seconds to 1 minute after the profile does not request it, so if you have it set to normal mode, it can take up to 1 minute to disable it.
Do you still have it on fast refresh? If so, we will need to do a teamviewer session to check it out
Postby jon.191023 » Tue Feb 13, 2024 5:04 pm
jon.191023
Postby TheLaGmAn » Tue Feb 13, 2024 5:45 pm
i think i found the issue why it wouldnt go back to normal mode.
Can you give it a try now? reboot the device if after a profile re-load it still doesnt work.
Postby jon.191023 » Tue Feb 13, 2024 6:10 pm
IT WORKS ONCE AGAIN !!!!!
The client device doesn't request fast refresh mode in the logs after the last reboot.
Very nice job.
Thx a lot for your help !!
jon.191023
