Firmware 235 to 245
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Firmware 235 to 245
Postby TheLaGmAn » Mon Feb 08, 2021 2:45 pm
DO NOT UPDATE YOUR FIRMWARE UNLESS THERE IS A FEATURE ON IT THAT YOU NEED.
ONLY UPGRADE YOUR FIRMWARE WHEN ON GOVERLAY 1.6.9.11 OR NEWER
ONLY UPGRADE IF YOU ARE ON 235
Changelog on 245:
- Added feature to be able to turn the device 180 degrees. Works with GOverlay on at least 1.6.9.11
Risks on upgrading firmware:
If the upgrade is stopped half way it can brick the device.
If there is a disconnection during upgrade it can brick the device.
ONLY UPDATE IF YOU REQUIRE ANY OF THE FEATURES OF THIS UPDATE
Steps to upgrade firmware:
Re: Firmware 235 to 245
Postby 3eas00 » Mon Feb 08, 2021 6:49 pm
3eas00
Postby stossi30 » Mon Feb 08, 2021 11:43 pm
nice
stossi30
Postby Anzlinger » Tue Feb 09, 2021 3:45 pm
top
Anzlinger
Postby shotbybulletz » Tue Feb 09, 2021 9:46 pm
top
shotbybulletz
Postby shotbybulletz » Tue Feb 09, 2021 9:52 pm
I installed the firmware and i still dont have an option to rotate the display.
I have the 3.5 inch screen, updated from firmware 235 to 245, rebooted the device and goverlay software, no option in the settings tab to rotate the display. any help??
shotbybulletz
Postby TheLaGmAn » Wed Feb 10, 2021 1:07 pm
what goverlay version are you in?
Postby MikeeeMania » Thu Feb 11, 2021 9:20 pm
Thanks!
MikeeeMania
Postby wargamer861 » Mon Feb 15, 2021 6:01 pm
wargamer861
Postby The4sgard » Mon Feb 15, 2021 11:28 pm
Amazing, thank you so much! That was the missing part (Update) for my system! <3
The4sgard
Return to Firmware Updates
