Firmware 234 to 244
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Firmware 234 to 244
Postby TheLaGmAn » Mon Feb 08, 2021 2:45 pm
DO NOT UPDATE YOUR FIRMWARE UNLESS THERE IS A FEATURE ON IT THAT YOU NEED.
ONLY UPGRADE YOUR FIRMWARE WHEN ON GOVERLAY 1.6.9.11 OR NEWER
ONLY UPGRADE IF YOU ARE ON 234
Changelog on 244:
- Added feature to be able to turn the device 180 degrees. Works with GOverlay on at least 1.6.9.11
Risks on upgrading firmware:
If the upgrade is stopped half way it can brick the device.
If there is a disconnection during upgrade it can brick the device.
ONLY UPDATE IF YOU REQUIRE ANY OF THE FEATURES OF THIS UPDATE
Steps to upgrade firmware:
Re: Firmware 234 to 244
Postby TheNiele » Tue Feb 09, 2021 8:18 am
Thank you !
TheNiele
Postby MikeeeMania » Thu Feb 11, 2021 9:26 pm
Thanks!
MikeeeMania
Postby Expatriate » Sun Feb 14, 2021 5:18 am
Expatriate
Postby blesja » Sun Feb 14, 2021 2:14 pm
blesja
Postby DarkNinja0860 » Tue Feb 16, 2021 4:41 pm
thx
DarkNinja0860
Postby Nightshot83 » Wed Feb 17, 2021 11:45 am
thx :D
Nightshot83
Postby JensNN1978 » Thu Feb 18, 2021 3:48 am
JensNN1978
Postby ooogeee » Thu Feb 25, 2021 9:33 am
thnks
ooogeee
Postby CobarGaming » Fri Feb 26, 2021 10:59 am
CobarGaming
Return to Firmware Updates
Users browsing this forum: No registered users and 10 guests
