Firmware 232 to 242
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Firmware 232 to 242
Postby TheLaGmAn » Sat Feb 06, 2021 8:38 pm
DO NOT UPDATE YOUR FIRMWARE UNLESS THERE IS A FEATURE ON IT THAT YOU NEED.
ONLY UPGRADE YOUR FIRMWARE WHEN ON GOVERLAY 1.6.9.11 OR NEWER
ONLY UPGRADE IF YOU ARE ON 232
Changelog on 242:
- Added feature to be able to turn the device 180 degrees. Works with GOverlay on at least 1.6.9.11
Risks on upgrading firmware:
If the upgrade is stopped half way it can brick the device.
If there is a disconnection during upgrade it can brick the device.
ONLY UPDATE IF YOU REQUIRE ANY OF THE FEATURES OF THIS UPDATE
Steps to upgrade firmware:
Re: Firmware 232 to 242
Postby TheNiele » Sun Feb 07, 2021 1:52 am
Thank you
TheNiele
Postby Screamo » Mon Mar 01, 2021 5:42 pm
thx
Screamo
Postby Meru1212 » Sat Mar 06, 2021 6:57 am
thy
Meru1212
Postby MZman58 » Wed Mar 10, 2021 9:05 pm
thx
MZman58
Postby Olec01 » Thu Mar 11, 2021 1:35 pm
Olec01
Postby Phelan_H » Fri Mar 26, 2021 10:50 am
thx
Phelan_H
Postby Sub200 » Fri Mar 26, 2021 12:17 pm
Thx;)
Sub200
Postby JohnnyBlack » Sat Mar 27, 2021 4:04 pm
thanks!
JohnnyBlack
Postby carmyyy » Mon Mar 29, 2021 6:36 pm
TheLaGmAn wrote:.
Changelog on 242:
If there is a connection during upgrade it can brick the device.
carmyyy
Return to Firmware Updates
