Firmware 231 to 241
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Firmware 231 to 241
Postby TheLaGmAn » Sat Feb 06, 2021 8:18 pm
DO NOT UPDATE YOUR FIRMWARE UNLESS THERE IS A FEATURE ON IT THAT YOU NEED.
ONLY UPGRADE YOUR FIRMWARE WHEN ON GOVERLAY 1.6.9.11 OR NEWER
ONLY UPGRADE IF YOU ARE ON 231
Changelog on 241:
- Added feature to be able to turn the device 180 degrees. Works with GOverlay on at least 1.6.9.11
Risks on upgrading firmware:
If the upgrade is stopped half way it can brick the device.
If there is a disconnection during upgrade it can brick the device.
ONLY UPDATE IF YOU REQUIRE ANY OF THE FEATURES OF THIS UPDATE
Steps to upgrade firmware:
Re: Firmware 231 to 241
Postby TheOne90 » Mon Feb 08, 2021 7:08 pm
Tanks :D
TheOne90
Postby stossi30 » Mon Feb 08, 2021 11:47 pm
thx
stossi30
Postby Juerg87 » Fri Feb 12, 2021 10:44 pm
thx
Juerg87
Postby xANACONDAx » Sat Feb 13, 2021 12:50 pm
thx
xANACONDAx
Postby Ralle86 » Sun Feb 21, 2021 5:59 pm
thx :)
Ralle86
Postby asamson23 » Thu Feb 25, 2021 11:27 pm
asamson23
Postby Screamo » Mon Mar 01, 2021 5:40 pm
thx
Screamo
Postby ultra-S » Thu Mar 04, 2021 7:43 pm
thx
ultra-S
Postby calibra71 » Fri Mar 05, 2021 12:11 am
Can I upgrade from 219 to something like 241? need also 180° turn.
thx
calibra71
Return to Firmware Updates
