Firmware
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Firmware
Postby stress_1974 » Tue Feb 02, 2021 1:34 pm
hi, is there any way to upgrade the firmware?
Thanks!!
stress_1974
Re: Firmware
Postby TheLaGmAn » Tue Feb 02, 2021 1:50 pm
At the moment we only have a firwamre upgrade from 231 to 241 only, to allow for the 180d feature, but only in that firmware path.
Different devices have different versions, for example, this update is not compatible with firmware 232, forcing an update would brick the device since 232 > 241 is not compatible.
Are you aiming to firmware upgrade for the 180d or something else?
Re: Firmware
Postby stress_1974 » Tue Feb 02, 2021 1:53 pm
yes that is what i need!!! for the 180 degree
damn....my firmware is 232.........
stress_1974
Re: Firmware
Postby stress_1974 » Sun Feb 07, 2021 4:56 am
works fine!!!
THANKS!!!!!!!
stress_1974
Return to Firmware Updates
Users browsing this forum: No registered users and 10 guests
