Turning display 180 degrees
Everything regarding firmware updates on LCDSysInfo2 (3.5'')
Postby TheLaGmAn » Wed Jan 27, 2021 1:31 pm
Can you please reply here whoever wants the display to be turned 180d?
Please reply with your firmware version, you can find it in the Tools tab
Re: Turning display 180 degrees
Postby Nike7230 » Thu Jan 28, 2021 10:13 am
That would be very useful in my case (NZXT H210i)
Firmware: 231
Nike7230
Postby Cadeyrn » Sat Jan 30, 2021 3:23 pm
I mounted it a bit more complicated in the "normal" orientation now, but would have been happy and easier to have had the option to turn it around!
Cadeyrn
Postby Holzwurm81 » Sat Jan 30, 2021 6:33 pm
that would be a really great feature.
Got my Display today and it will go into a H210i also :)
Would be great to have Display Rotation :)
FW 231 here to
Markus
Holzwurm81
Postby annoyedmilk » Sun Jan 31, 2021 12:53 am
Hi TheLaGmAn
I would really welcome this feature!
Firmware: 231
annoyedmilk
Postby nikkdizzle » Fri Feb 05, 2021 8:00 pm
I would love to be able to turn 180d
firmware 231
nikkdizzle
Postby TheNiele » Sun Feb 07, 2021 10:03 pm
Hi, is it possible to update the firmware from version 234 to 242?
TheNiele
Postby Expatriate » Sun Feb 14, 2021 5:17 am
hi
my frimware 244
It would be great to rotate it 90 degrees for mounting inside the case. USB to the bottom
Expatriate
Postby TheLaGmAn » Sun Feb 14, 2021 4:04 pm
rotation is only for 180d, we cant rotate 90d
Postby Expatriate » Tue Feb 16, 2021 12:10 am
TheLaGmAn wrote:rotation is only for 180d, we cant rotate 90d
Hi TheLaGmAn
wouldn't it be great 90d though?
Expatriate
Return to Firmware Updates
