Profile: System Command Center
Postby ppgrainbow » Wed Jan 09, 2019 2:19 am
Basic system information that displays all of the information on your computer, such as current date, time, weather condition, CPU, GPU, memory, disk, networking and volume information.
All of the vital sensor information is displayed which includes the temperatures of the CPU, motherboard, GPU and hard disks. I'm using GOverlay 1.6.7 to display all of these sensors with the updated HWiNFO plugin.
Let's hope that another beta or stable update of GOveraly is released. For now, enjoy my profile. :)
System Command Center.png (10.24 KiB) Viewed 10861 times
System Command Center.gov
(165.52 KiB) Downloaded 1513 times
If you have any comments or questions about the System Command Center profile, let me know and I'll do everything I can to update it from here.
ppgrainbow
Re: Profile: System Command Center (Beta)
Postby TheLaGmAn » Thu Jan 10, 2019 5:53 pm
Could you contact me at support@goverlay.com ? The images on your profile are missing and i would like to check with you what the issue is.
Postby ppgrainbow » Thu Jan 10, 2019 7:42 pm
TheLaGmAn wrote:Could you contact me at support@goverlay.com ? The images on your profile are missing and i would like to check with you what the issue is.
I sent you a note regarding which images are required. Are you asking for the font image files or the bitmap files? Just curious, because I might not have done it right and I'm new to customisation and reporting issues here.
I haven't been on this site for more than three years, because I apparently broke the micro USB dongle on my LCDsysinfo 2.8" product after about two weeks of use. :(
UPDATE: I think that I found the problem what caused the profile to not load images:
2019/1/11 11:30:27:Profile Export - Error gathering images Public member 'Controls' on type 'FakeControl' not found. ::    at Microsoft.VisualBasic.CompilerServices.Symbols.Container.GetMembers(String& MemberName, Boolean ReportErrors)
   at Microsoft.VisualBasic.CompilerServices.NewLateBinding.ObjectLateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
   at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
   at aa.b(Object A_0, Object A_1, Object A_2, Object A_3, Object A_4)
   at GOverlay.Form1.a(Object A_0, Object A_1, Object A_2, Object A_3, Object A_4)
Let's hope that a new beta comes out soon so that I can continue working on improving this profile more. :)
UPDATE 2: Thank you for fixing the bug that caused the sensors for the two other hard drives to not work correctly when using the HWiNFO plugin. I'll do more work on my profile and update with the final version. :)
UPDATE 3: I've noticed that GOverlay 1.6.7 was released moments ago! Thank you for fixing the bugs that caused some of the sensors in the HWiNFO plugin to not work properly. :)
ppgrainbow
Return to Shared Profiles
