Profile: Advanced Info Profile 4Core 3Disk version (LCD2)
Postby DooMknight87 » Sat Jun 23, 2018 2:42 pm
ts3icons.rar
Teamspeak icons to upload on the device
(3.14 KiB) Downloaded 1182 times
AdvancedInfoprofile4Cores3Diskversion.gov
Profile
(265.38 KiB) Downloaded 1398 times
Screenshot
DooMknight87
Re: Profile: Advanced Info Profile 4Core 3Disk version (LCD
Postby ReddishCat » Tue Jul 17, 2018 1:44 pm
Hello
I am missing most of the icons. It currently looks like this:
The icons should be in \GOverlay\LCDSysInfo2\default-files\ don't they? these are all the icons in that folder for me: https://i.imgur.com/nadPVFW.png
I have probably fucked everything up 1year+ ago. The last time I fucked around with it.
Also I don't understand what kind of sensor I am supposed to put in this. Should it repesent vram? https://i.imgur.com/hUcjeJS.png
I Have ohm and siv but I don't think they have a sensor for Vram
Thanks in advance.
ReddishCat
Postby DooMknight87 » Tue Jul 17, 2018 11:50 pm
DooMknight87
Postby ReddishCat » Wed Jul 18, 2018 9:38 pm
I fixed it
Just posting this here for other people running into this problem.
I found all the icons That I was missing in\GOverlay\LCDSysInfo2\downloaded-files\. Its seems to be a folder where all the icons are placed so they can be uploaded to the device.
So I tried manual uploading them but the software does not accepts the PNG files. PNG's are the only files that I am missing. It only allows BMP and BIN files as you can see here https://i.imgur.com/2ST7Ynw.png
I changes all the PNG files to BMP. This let me upload them to my device and get this profile working 100% yay :D
I looked at the logs of when I imported the profile and this PNG thing seems to be the whole problem. https://i.imgur.com/PfULsRG.png full log here: https://pastebin.com/QHpCttBL
Can someone try to upload a PNG file to there device and tell me if its working for them? Thanks ;)
ReddishCat
Postby TheLaGmAn » Mon Jul 23, 2018 2:38 pm
Postby DooMknight87 » Fri Sep 21, 2018 5:40 pm
DooMknight87
Return to Shared Profiles
