Profile: Republic of Drivers 1.1
Postby DooMknight87 » Thu Jun 08, 2017 10:00 pm
***DEPRECATED*** See new version:
Profile inspired on ASUS RoG products. It has all the information a gamer needs. Shows nice animations, all with an aggressive but elegant style.
The needles show the use of cpu (left) and gpu (center). The white bars inside those two gauges show the temperature, also shows it numerically in the center.
On the right is the memory indicator, where the sidebar shows the memory used, in addition to displaying the numerical values.
Finally, below I've put the information for an SSD and HDD (the most typical configuration), an animated icon of connectivity that is activated when there is network data flow, showing upload and download and the volume icon.
Update 1.1:
Added animation on both disks when sensor detects disk activity.
Fixed disk space units, now showing gb instead mb.
Some minor fixes.
Update 1.2:
Added write state animation on both disk sensors.
RepublicofDrivers.gov
Profile
(3.59 MiB) Downloaded 4873 times
Screenshot
DooMknight87
Re: Republic of Drivers 1.2
Postby itlvk » Tue Sep 12, 2017 4:17 am
Import error, please help
itlvk
Postby TheLaGmAn » Wed Sep 13, 2017 12:28 pm
Try the new version, i think i found the issue.
Postby JPVann » Thu Jan 17, 2019 2:42 pm
I'm new. What are you using for sensor data? I uploaded the profile but no info except for incorrect memory usage. Thanks!
JPVann
Postby TheLaGmAn » Thu Jan 17, 2019 5:54 pm
Postby Gronar » Sun Apr 28, 2019 4:56 am
How do I config sensor data to items under the sensor needle boxes in the profile screen of Goverlay? It's not showing my CPU temp and if I move the sensor needle box to get to it then I can't get it back to where it was so everything is lined up and pretty again.
Gronar
Postby Mage_Mors » Wed May 15, 2019 8:50 pm
Is this complete. I imported it and all I get is the layout with no graphics or anything ?
I am new to the forums.. I used the 2.5 goverlay for years.. all I wanted was a bigger screen so I just go the 3.5. Seems all the stuff I could do in the 2.5 and special objects are not available in the 3.5 version
Mage_Mors
Postby TheLaGmAn » Thu May 16, 2019 1:05 pm
did it prompt you to upload the pictures to the device?
Return to Shared Profiles
