Profile: breach-protocol (LCD2)
Postby hal-sariph » Sun Dec 24, 2023 5:46 pm
--PLEASE SEE NEWEST VERSION IN NEW POST--
Inspired by Cyberpunk 2077. Displays CPU temp, GPU temp, CPU core usage, date, and time.
Current design is based on a 16 core CPU. Sensor data is pulled from Open Hardware Monitor.
(Edited image on post to show newer version)
breach-protocol.gov
Profile
(179.22 KiB) Downloaded 3921 times
hal-sariph
Re: Profile: breach-protocol (LCD2)
Postby hal-sariph » Mon Dec 25, 2023 2:14 am
Adjusted the layout a bit for clock spacing issues at certain times.
(I think the objects should have warnings on them when their size is not large enough to fit all permutations of the sensor they pull from)
breach-protocol-V2 (LCD2).gov
Updated Profile
(179.23 KiB) Downloaded 3700 times
hal-sariph
Postby hal-sariph » Thu Jan 02, 2025 9:08 pm
I worked on the layout a little bit. Tightened up the lower section to allow for Ram usage graph and loosened up the top section so the time and day shouldn't overlap anymore. (I will have to keep an eye out for the next week and confirm)
breach-protocol-v3 (LCD2).gov
(186.33 KiB) Downloaded 2744 times
hal-sariph
Return to Shared Profiles
Users browsing this forum: No registered users and 10 guests
