Profile: Universal-Stat for any configuration (LCD2)
Postby ExileTM » Wed Oct 06, 2021 7:34 am
universalstat.gov
Profile Universal-Stat for LCDSysInfo 3.5"
(790.94 KiB) Downloaded 1773 times
Universal Stat
ExileTM
Re: Profile: universal stat (LCD2)
Postby ExileTM » Wed Oct 06, 2021 7:40 am
In version 1.2 has been inserted the grid for the two graphs that represent in real time the performance of your CPU and GPU.
In addition to having to download the updated wallpaper (always from the link of the first post) and apply it through the GOverlay software, it is good to take a couple of things into consideration. As in the image below, you will have to enter your maximum "scale" of CPU and GPU power, entering the correct value (to have the highest possible fidelity).
For example, if you have a 3.7Ghz CPU (no matter how many cores), then you will have to enter 3700 as the value, same for a 4.2Ghz CPU, then you will enter 4200 and so on.
Same thing to do with your graphics card. Set the value of your GPU, going to change the value of the graph.
ExileTM
Re: Profile: Universal-Stat for any configuration (LCD2)
Postby ExileTM » Fri Oct 08, 2021 9:30 pm
reserved
ExileTM
Postby TheLaGmAn » Mon Oct 11, 2021 2:21 pm
Wow, thanks for sharing and the detailed guide! looks very cool
Return to Shared Profiles
