Profile: sub200_tech_2021 (LCD2)
Postby Sub200 » Thu Jan 07, 2021 7:32 pm
My first layout;) The following sensors are active in combination with AIDA64:
GPU & CPU temperature incl. Utilization & memory clock and the time.
Then the temperatures of all hard disks & the displayed free disk space.
If someone wants to adjust the layout for themselves, no problem.
If you have any questions or suggestions, just write;)
sub200tech2021.gov
Profile
(690.49 KiB) Downloaded 2078 times
Screenshot
Sub200
Re: Profile: sub200_tech_2021 (LCD2)
Postby Bad_Lieutenant » Wed Jan 20, 2021 7:42 pm
Would it be possible to get the Background as an image to download?
Bad_Lieutenant
Postby Sub200 » Wed Jan 20, 2021 10:28 pm
Sure, i try to finish it tomorrow and send you a PM with the download Link:)
Sub200
Postby Bad_Lieutenant » Thu Jan 21, 2021 12:27 am
Thank you very much
Bad_Lieutenant
Postby cleaner-sn » Sun Apr 25, 2021 6:03 am
cleaner-sn
Postby Feivel » Mon Apr 26, 2021 4:08 pm
Hi, I'm new to the display and like your design.
I would like to do some changes to it (especially putting it in the colour schema of my PC).
Would you share it with me as well?
Thanks in advance for your great work. :)
Feivel
Return to Shared Profiles
Users browsing this forum: No registered users and 20 guests
