Green flavored version of the
Green image files are named with _g at the end of their file name for compatibility with the other colors, this way it's possible to combine the different colors that you have downloaded from other color profiles, for example if you like the red temperature icon you can use the original profile red icon...
The fan icons and RoG logo in the corner can be removed or moved after the profile is imported. I've put to get them uploaded to the device when the profile import is done
