Profile: Republic of Drivers 2.5 **OUTDATED**
Postby DooMknight87 » Thu Sep 03, 2020 5:39 pm
RepublicofDrivers20.gov
Profile
(1.1 MiB) Downloaded 2072 times
Screenshot
Last edited by DooMknight87 on Fri May 21, 2021 3:27 pm, edited 18 times in total.
DooMknight87
Re: Profile: Republic of Drivers 2.0
Postby DooMknight87 » Thu Sep 03, 2020 11:01 pm
Profile variants:
by DooMknight87
Green version
by DooMknight87
Cyan version
by DooMknight87
Digital version of the Republic of Drivers profile, the needles have been removed to provide a larger and more detailed plot graphic, percentage of use values and some minor tweaks.
by DooMknight87
Another variant from the RoD 2.5 profile. In this version the needles are kept but the plots have been removed, offering the usage info in %. Fan information has also been added in the miscellaneous section.
by ataking99
Added fans and latency meter
Previous versions
Optional files:
Here I'll be adding optional files such as icons, fonts, loading images, alternate backgrounds ...
Splash screens:
Font used for text and values:
DooMknight87
Postby wackid » Tue Oct 20, 2020 7:50 pm
Mannnn. This lay-out is so sick. Its one of the reasons i bought a display.
Many many thanks!!!
I have only on thing the file rpd_oldbck is too low in the image how can i get it upward?
Edit:
Got it working... What I did wrong....is first to activate the profile and the upload the icons...
After re uploading the *.gov file it was loading fine.
When i put the Splash screen as a back ground the height is okay. The gauges fit with the needles.
wackid
Postby lucas001 » Mon Nov 02, 2020 10:50 am
Hey mate, amazing profile! could you please tell me where to I adjust the GPU temp? which box do I need to edit? I clicked everywhere and couldn't find it. thanks!
lucas001
Postby TheLaGmAn » Tue Nov 03, 2020 2:11 pm
That sensor is hidden behind the "sensor needle", so you will need to first move the "sensor needle" to see the sensors behind it.
Select "sensor needle" and use the move option to "move by 10" and move it to the right 12 times so then you can move it back to position by moving 12 times again to the left, do not move it manually with the mouse or you will have a hard time getting the original position back.
Same goes for the other sensor needle.
Postby lucas001 » Tue Nov 03, 2020 10:21 pm
lucas001
Re: Profile: Republic of Drivers 2.5
Postby DooMknight87 » Sun Nov 08, 2020 10:54 pm
**UPDATED PROFILE TO 2.5**
- Added the variants to the second post
- Added downloads to the previous versions
DooMknight87
Re: Profile: Republic of Drivers 2.5 **UPDATED**
Postby djsprc » Wed Feb 03, 2021 7:15 pm
I want to know if it's possible to change the colour of the accent from red to blue
Any help will help i never use this program before
djsprc
Postby Sub200 » Fri Feb 12, 2021 9:40 am
Nice work;)
Sub200
Postby marcus_hh » Wed Feb 17, 2021 10:45 am
Awesome profile!
I cant find the downloadlink, need help :oops:
thx
marcus_hh
Return to Shared Profiles
Users browsing this forum: No registered users and 20 guests
