New 3.5 LCD - HWINFO Not Showing Sensors
Postby JPVann » Thu Jan 17, 2019 3:50 pm
I have the most recent updated GOverlay and HWINFo. HWINFO is enabled and open, shows as a line item in GOverlay but no sensor data.
Any help appreciated! Thanks!
JPVann
Re: New 3.5 LCD - HWINFO Not Showing Sensors
Postby TheLaGmAn » Thu Jan 17, 2019 5:55 pm
Can you send me the log of goverlay to support@goverlay.com ?
Postby BerMM » Wed Jul 03, 2019 7:13 pm
I ran into this as well. Configuration Wizard doesn't show HWiNFO64 sensors, nor could I figure out how to enter my location for weather. No matter what I put in I got a blank popup. Configuration Wizard can see other sensors, but not HWiNFO64. Enabling from Plugins tab does not add it to the Configuration Wizard. HWiNFO doesn't show on Sensors tab, but it does on Charts. HWiNFO also shows as an option when I click an element on LCDSysInfo 3.5 -> Profiles. That is also how I was able to successfully enter my weather location.
BerMM
Postby TheLaGmAn » Fri Jul 26, 2019 11:38 pm
i didnt understand if you still have issues, but if you do, try the beta 1.6.9.2_mel
Postby Cortus » Fri Jul 29, 2022 9:51 pm
Thanks !
Cortus
Users browsing this forum: No registered users and 24 guests
