RTSS has been updated to 6.5
Postby SubSonix » Sun Nov 06, 2016 11:37 am
And I'm not sure If It's still comparable.
With RTSS 6.5 running, goverlay doesn't seem to detect games and change to the gaming profile nor does it detect FPS.
This might just be something I'm doing wrong, but please let me know If it works for you.
Hoping for an update of goverlay if need be :)
SubSonix
Re: RTSS has been updated to 6.5
Postby TheLaGmAn » Thu Nov 17, 2016 4:07 pm
It should work, i havent tested it myself, but unless something drastically changed, it should still work.
Can you check the status tab of GOverlay to see the 3D apps detected? Also, which game are you testing, it could be a specific DX version not detected.
Postby SubSonix » Thu Nov 17, 2016 6:31 pm
I'll give it another try asap, and let you know. (I rolled back in the meantime)
SubSonix
Postby SubSonix » Fri Nov 18, 2016 11:11 am
TheLaGmAn wrote:It should work, i havent tested it myself, but unless something drastically changed, it should still work.
Just to clarify, RTSS 6.5 added support for DX12
This is my goverlay with RTSS 6.5 -
So, It's still detecting everything right I believe, just that the profile Isn't switching to "While gaming" nor is it detecting FPS in "APP: 3D Stats - Current FPS"
Let me know If you need any other info.
I've only changed RTSS version, nothing else on my system has changed.
*EDIT* - Just got this info from the RTSS creator:
"There were some changes in RTSS shared memory layout related to 3D API identification flags interpretation after adding DX12 support. Most likely GOverlay rely on that data and stop displaying FPS if it cannot identify 3D API properly. If that's the case, then shared memory version handling should be added there."
SubSonix
Postby TheLaGmAn » Fri Nov 18, 2016 5:18 pm
Thanks for the info including the unwinder comments!
Try this version
http://goverlay.com/UserFiles/GOverlay/ ... _2016a.zip
Its just the rtss_hook.dll, overwrite the one in your GOverlay folder (make sure GOverlay is not running first), and see if it detects the games.
Postby SubSonix » Fri Nov 18, 2016 8:56 pm
That kinda broke it :P
Thank you for trying though, happy to be your guinea pig for testing purposes :)
*Edit* This happens when I close goverlay with that new RTSS_Hook.dll
SubSonix
Postby TheLaGmAn » Sat Nov 19, 2016 2:39 pm
Did you overwrite the older version?
Do a right click on the RTSS_Hook.dll and click on properties, in the security tab, make sure the file is not locked
Postby SubSonix » Sun Nov 20, 2016 3:40 am
TheLaGmAn wrote:Did you overwrite the older version?
Yes and not locked
Just checked the log file -
20/11/16 2:39:21 PM:Error doing OUT render: Unable to load DLL 'rtss_hook.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
20/11/16 2:39:21 PM: at GOverlay.Form1.DoRender(IntPtr A_0, String A_1, Int32 A_2)
at GOverlay.Form1.a(IntPtr A_0, String A_1, Int32 A_2)
That repeats constantly.
*Edit* Unrelated, but is it possible to subscribe to this thread?
SubSonix
Postby TheLaGmAn » Sun Nov 20, 2016 4:19 pm
I enabled the subscribe.
Try this version:
http://goverlay.com/UserFiles/GOverlay/ ... _2016b.zip
You need all 4 files, put them in the GOverlay folder
Postby SubSonix » Mon Nov 21, 2016 3:32 am
TheLaGmAn wrote:I enabled the subscribe.
Try this version:
So far so good, working with DX12 games now too :)
I'll let you know If I have any issues at all.
Thank you for working on this for me, hopefully others find it useful too :)
SubSonix
Users browsing this forum: No registered users and 21 guests
