TheLaGmAn wrote:This plugin allows to read HWiNFO sensors and load them into GOverlay.
IMPORTANT: You need this BETA as minimum to use this plugin
http://www.goverlay.com/forum/viewtopic.php?f=3&t=19
GOverlay + HWiNFO 6.X
You can still use HWiNFO 6.X with GOverlay as usual.
GOverlay + HWiNFO 7.X FREE LICENSE
If you intend to use HWiNFO 7, it works with GOverlay but depends on your HWiNFO license.
If you use free license, you have to start HWiNFO in full mode, go to settings and enable shared memory support as the next image shows
http://prntscr.com/10ha3s3
After this, you still need to open the sensors tab, otherwise it will not send sensors info.
After you do this two steps, GOverlay will be able to read HWiNFO data from 12 hours straight, after that, you need to re-enable HWiNFO shared memory support
GOverlay + HWiNFO 7.X PRO LICENSE
You can still use HWiNFO 7.X with GOverlay as you used to use it with 6.X.
Download & Install instructions:
Users browsing this forum: No registered users and 17 guests
