NiceHash - BTC Mining Plugin (BETA) v0.1
Postby TheLaGmAn » Wed May 19, 2021 9:57 pm
For anyone mining on NiceHash, here is a plugin to fetch your RIG information (megahash, profitability, speeds, watts usage).
Very early beta, may or may not work properly.
You only need your public miner wallet id to use the nicehash api (does not use nicehash credentials).
Add it on the plugin options.
Re: NiceHash - BTC Mining Plugin (BETA) v0.1
Postby dalupus » Thu May 27, 2021 3:58 am
what I want to know is where you got your hands on 2 3090's :)
Thanks for this, I'll try it out.
dalupus
Postby chicky » Sat May 29, 2021 1:41 pm
Thanksa lot
chicky
Postby bezibaerchen » Sun May 30, 2021 11:53 am
Looks nice, will give it a try
bezibaerchen
Postby inkjunkie » Tue Sep 28, 2021 8:29 pm
thank you!
inkjunkie
Postby loois007 » Mon Nov 29, 2021 8:30 pm
loois007
Postby Giveatry » Sat Dec 04, 2021 9:12 pm
Will try.
Giveatry
Postby ChaosMage » Tue Feb 08, 2022 5:17 pm
thanks!
ChaosMage
Postby ChaosMage » Tue Feb 08, 2022 5:58 pm
might be useful to be able to configure the polling rate, getting an error:
2/8/2022 9:57:00 AM:NiceHash plugin - error on grabdata: https://api2.nicehash.com/main/api/v2/m ... veWorkers-> The remote server returned an error: (429) Too Many Requests. :: at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at GOverlayPlugin.NiceHash.Class1.grabdatathread()
ChaosMage
Postby heslo » Fri Aug 12, 2022 11:05 am
Nice, cheers!
heslo
Users browsing this forum: Google [Bot] and 1 guest
