Aquasuite
Aquasuite
Postby muckie89 » Sat Jan 02, 2021 5:49 am
Ahoi, i installed GOverlay and prepared the plugin like i should. I linked the aquasuite xml and enabled the plugin. Also i enabled the xml export in aquasuite.
No Sensor Data and nothing shows up. The only thing which appeard is .... aquasuite under profile were i can create my own design.
I think most people having problems setting up this plugin. The Aqueros are the most powerfull controllers in the world so it should work.
muckie89
Re: Aquasuite
Postby TheLaGmAn » Sat Jan 02, 2021 6:44 pm
From what i see on the screenshots, it seems like the aquasuite xml file is being generated on "c:\" and goverlay is set to load it up from "c:\programdata\...", so those locations dont seem to match up.
Can you check if you actually have the file where you pointed goverlay to fetch it from?
Re: Aquasuite
Postby peg1988 » Mon Aug 29, 2022 8:42 pm
i have the same problem
my go overlay dont see aquasuite sensors anymore, before 3 days it works normal but now i dont see no sensor from aquasuite on go overlay ...
peg1988
Re: Aquasuite
Postby TheLaGmAn » Tue Aug 30, 2022 11:12 pm
is the aquasite file being generated in the right place?
