LibreHardwareMonitor Support
Postby Timm0 » Sun Dec 08, 2019 8:22 pm
a fork of Open Hardware Monitor with newer CPU e.g Support.
I would like to see my Ryzen Temp on my tiny display ;-)
greets from Germany
Timm0
Timm0
Re: LibreHardwareMonitor Support
Postby TheLaGmAn » Wed Dec 11, 2019 6:53 pm
i been taking a look and seems like it requires net framework 4.5 and we are using 4, i will look into upgrading and see what happens
Postby Timm0 » Sat Dec 14, 2019 8:46 pm
thx ;-)
Timm0
Postby TheLaGmAn » Sun Dec 29, 2019 7:29 pm
several issues come up when upgrading to .net framework 4.5 due to our RTSS library, i cant get it to work, would of been awesome if lhm was on .net4
Postby Timm0 » Sat Jan 04, 2020 9:35 am
damn it ;-)
at some month earlier i had a OHM version that work with Ryzen but this is no more available and i cant find it anymore in the internet :-/
Timm0
Postby TheLaGmAn » Wed Jan 29, 2020 3:25 pm
i would like to upgrade and we would be able to use this library but the module that connects to RTSS just crashes, the issue is the RTSS library, never been able to implement it on VB.NET and had to use a separate module in C++, still looking to ways to integrate it directly into VB.NET but so far havent been able to
Postby TheLaGmAn » Sun Feb 09, 2020 6:25 pm
im testing a new RTSS library that allows me to upgrade to framework 4.5.2, if this library works, then we can use LHM, its been implemented on the BETA, give it a try and let me know how it works
viewtopic.php?f=3&t=1594
Postby Timm0 » Sun Apr 12, 2020 10:28 pm
THX for LHW Support ;-) Great Work!!!
Timm0
Users browsing this forum: No registered users and 21 guests
