Larger usb display
Larger usb display
Postby Nimzovich » Sat Jul 25, 2015 4:25 am
Is it possible to run GOverlay on a larger usb display like this one:
http://www.lcdinfo.com/products/usbd480-wq43.html
If so, how does one go about it?
Nimzovich
Re: Larger usb display
Postby TheLaGmAn » Thu Jul 30, 2015 3:38 am
Hi, sadly, no, we dont have a bigger screen product and its not just about the screen, it would need more processing power to handle a bigger screen.
Postby wiretap » Thu Aug 27, 2015 12:05 am
For a display like that, you could probably use Aida64's external monitor support, and use it as a secondary screen with widgets you build. You'd have to check to see if it is supported. For nearly the same price though, it would be better to go with a 7" 800x480 resolution screen, like a Mimo.
wiretap
