GOverlay BETA 1.6.7.1
Postby TheLaGmAn » Sun Jan 20, 2019 7:55 pm
Version 1.6.7.1:
Potential fix for weather.
Re: GOverlay BETA 1.6.7.1
Postby ppgrainbow » Sun Jan 20, 2019 8:11 pm
I'll be updating now to see if it fixes the 0 degree Celsius/Fahrenheit bug on startup and go from there. :)
Yay! :D The update worked! Thank you so much! :)
ppgrainbow
Postby tedharris600 » Sun Jan 20, 2019 8:24 pm
Thank you.
Weather is still broken.
No matter what location I put in, the temperature is still 0. Is there an example of a location that works? What format should the weather location be in?
The log file shows:
1/20/2019 3:31:59 PM:WeatherPull (Global) - Getting weather info - 0 weathers
1/20/2019 3:31:59 PM:WeatherPull (Global) - Thread ended
My log file is attached.
log.txt
(14.51 KiB) Downloaded 10114 times
tedharris600
Postby TheLaGmAn » Sun Jan 20, 2019 9:53 pm
tedharris600 wrote:Thank you.
The log file shows:
"new york, usa" for example will work.
you are using only lcdsysinfo 2.8?
Where is the weather set up? in the notification box or where?
Hit save on your profile and grab all the contents of the log window of goverlay and attach them here
Postby tedharris600 » Mon Jan 21, 2019 3:16 am
Hello,
I am using the 3.5" LCDsysinfo only.
I am trying to use the built in weather sensor that is in the "notification box" as shown below.
I just realized that I can manually add a weather sensor from "Dark Sky". That seems to work for the temperature and weather condition as text, but I don't know how to set up the weather condition icons (cloudy, rainy, etc.) that were present in the "notification box".
Here is the log file:
tedharris600
Postby TheLaGmAn » Mon Jan 21, 2019 3:27 am
in the notificaction box, does it show the temperature in numbers?
Postby tedharris600 » Mon Jan 21, 2019 3:32 am
Hello,
The notification box shows 0 as the temperature and a blue cloud icon as shown below. Neither the temperature nor the icon ever change.
Thank you.
tedharris600
Postby triryche420 » Mon Jan 21, 2019 4:06 am
Mine never came back at 0 but as "-11" mostly. Using 2.8 display notification box. Will let ya know if this remedies.
Log showed
1/20/2019 8:02:41 PM:WeatherPull (Global) - Temperature is: -11.6666666666667 (-686/-11.6666666666667)
1/20/2019 8:02:40 PM:WeatherPull (Global) - 1456801617.95656 : Fetching temperatures: 144 / F
EDIT:
My weather is working perfectly now, thanks much!
triryche420
Postby tedharris600 » Mon Jan 21, 2019 6:57 am
Hello,
I have just discovered that I cannot export my profiles in this beta. I get the screen below.
I have to keep clicking through several dialog boxes that have the word "test" in them. The dialog boxes never seem to end. I finally have to kill GOverlay in task manager.
I am running Windows 10 Pro 64 bit version 1809 build 17763.253.
Thank you.
tedharris600
Postby TheLaGmAn » Mon Jan 21, 2019 1:25 pm
the export is a bug on this beta, download the 1.6.7.2 (its posted in the forum now).
Re the weather, its strange, its working for everybody now.
Please create a new profile (notification box), set only the weather to it and hit save, wait 5 seconds after it shows in the display and then, go to the logs tab and copy all the contents of it and add them here
Users browsing this forum: No registered users and 23 guests
