GOverlay BETA 1.6.6.2
Postby TheLaGmAn » Mon Dec 17, 2018 4:24 am
Version 1.6.6.1:
- Added automatic driver installation for the 3.5'' device, there is an installer named GOverlay_Driver_Install.exe and it
can also be launched from within goverlay in the 3.5'' Tools tab, button "Install Driver". The installation signs the driver
in the computer itself avoiding to have to reboot the computer with driver enforce disabled to install it, it also installs
it itself without having to go thru the device manager. Requires testing to ensure it works on all computers.
- Fixes an issue on which the 3.5 display would show up as "not detected" in the status tab even though it will be working.
Thanks to Scorpion for reporting the bug!
Re: GOverlay BETA 1.6.6.2
Postby TheLaGmAn » Mon Dec 17, 2018 4:35 am
Please test the feature and let me know if any issues appear
Postby robb » Mon Dec 17, 2018 4:10 pm
Thanks will give it a go
*Edit works perfect for me thanks!
Postby goodppi » Mon Dec 17, 2018 10:13 pm
thx
goodppi
Postby DeLeTe3 » Tue Dec 18, 2018 12:03 am
:D
DeLeTe3
Postby Scorpion » Thu Dec 20, 2018 3:53 am
The Driver Installation works like a charm........Excellent!!!!
Scorpion
Postby skyhigh24 » Sun Dec 23, 2018 3:49 pm
8-)
skyhigh24
Postby skyhigh24 » Sun Dec 23, 2018 4:03 pm
not for the 2,8?
2018-12-23 17_02_58-GOverlay Forum • View topic - GOverlay BETA 1.6.6.2 – Opera.jpg
__________________________________________________________________________
Edit:
Got it to work, but only with a little Trick.
Replaced the Files from the 3,5 with the Files from 2,8, Changed some Lines in the Batch to Match the 2,8.
Then started the Driver Installer for the 3,5.
when this Message appeard,
i changed the driver.zip which was downloaded by the Installer to my modified one and pressed OK.
The Installer runs the modified batch and install the Drivers for the 2,8.
skyhigh24
Postby TheLaGmAn » Sun Dec 23, 2018 5:01 pm
We are testing with 3.5'' first, but glad to hear that its working for you on both :)
We will add 2.8 later on if this method seems to work for everyone
Postby skyhigh24 » Sun Dec 23, 2018 5:24 pm
I fully understand that :)
Was just courios, cause i use both versions on one PC. i wanted to try if it works for the 2.8 as well. Testet the "Standard-3.5-install" and the "Mod-2.8-Install" on 2 Guest-VM´s (Win 7 and Win 10) and my Host-PC (Win 10).it worked on all 6 Tests :)
skyhigh24
Users browsing this forum: No registered users and 23 guests
