GOverlay BETA 1.4.2 - Beta #10
Postby TheLaGmAn » Wed Mar 05, 2014 1:45 pm
Reply to see the link to the current BETA
Version 1.4.2 (BETA):
- BugFix: Fixed a bug on TS3 on which your nickname wasnt fetched right in some cases so you would see your nickname speaking instead of "You" when you spoke.
- BugFix: Fixed a bug on TS3 on which you would see your TS-Speaking-Icon enabled when you had your mic muted and you were speaking (but due to mic muted you shouldnt see the mouth light up)
- Improvement: You can now set how many points the plot graph will have,
so if you have a large graph you can set more points.
- BugFix: Fixed a bug on which in some countries the sensor bar graph, if
the show number option was enabled, the number might have a lot of numbers
if the number was not an integer.
- New Sensor: You now can select the network card to show the IP address
of, integrated with GOverlay without external applications.
- New Feature: You can now select profiles by right clicking on the tray
icon of GOverlay and selecting a profile from the "LCDSys 2.8 Profiles" menu
- BugFix: Fixed an issue in which in some cases the core#1#2#3#4 cpu usage
of OHMDLL was not showing correct values
- BugFix: Fixed an issue in which in some countries the maxdigits option for
sensors was not working right
- Improvement: Now the images uploader shows the calculated real slots the
image will use in the lcdsysinfo memory
- New Feature: Added an option in the GOverlay settings to be able to set
GOverlay to start as administrator
- BugFix: Fixed a bug on which when you selected an element from the list
you were not able to re-select it right away.
- New Feature: You can now set a formatting text in the sensor element, to
add text before and after the sensor value.
- New Feature: You can now set the maximum digits and add leading zeros to
the sensor element.
- New Feature: You can now set the maximum characters to show for the sensor
element.
- New Feature: You can now align the text to left or right in the sensor
element.
- BugFix: Fixed a bug on which the square text would always start with a space
before the text.
- Improvement: Added an option to remove the bar graph border if desired.
Re: GOverlay BETA 1.4.2 - Beta #10
Postby cyberrage » Wed Mar 05, 2014 2:23 pm
Will try it now and let you know by email =)
cyberrage
Postby thejudge911 » Mon Mar 10, 2014 8:52 pm
Will try it thx
*** works very nice ***
thejudge911
Postby OldElfin » Thu Mar 13, 2014 2:06 am
I will try it also. I love this thing.
OldElfin
Postby kilink » Tue Mar 18, 2014 7:24 pm
thank
kilink
Postby Tinkergnome » Thu Mar 20, 2014 3:02 pm
Tinkergnome
Postby alx » Thu Mar 20, 2014 8:27 pm
alx
Postby tbmalm » Thu Mar 20, 2014 11:52 pm
per our discussion, pulling down the beta
tbmalm
Postby stadtpirat » Sat Mar 22, 2014 5:27 pm
Thanks for your nice Tool.
I Love it.
stadtpirat
Postby ppgrainbow » Sun Mar 23, 2014 6:20 am
I love this update!
ppgrainbow
Users browsing this forum: Google [Bot] and 6 guests
