GOverlay BETA 1.6.4.9
Postby TheLaGmAn » Wed May 23, 2018 10:50 pm
Version 1.6.4.9:
- Added a new command to GOverlay.exe to load a 3.5 profile, ex: GOverlay.exe -activateprofile3.5 "template - blue (LCD2)"
- Added support for the option of OHM to specify the maximum digits to use for the sensors to apply to the built in OHM support.
- Added support for the "default gaming" profile, so you can create a profile with that name and any game that doesnt have a specific profile will use that one for gaming.
- Fixed issue for WPF applications for RTSS, GOverlay was not detecting them as games running (thanks SubSonix)
- Added option to the ImageBar to be able to pick a specific digit from the sensor to use as the value to draw (so you can use it to draw specific digit numbers)
- Added a new command to GOverlay.exe to load a 2.8 profile, ex: GOverlay.exe -activateprofile2.8 "template - blue (LCD2)"
- Fixed issue not letting VS add any boxes.
- Fixed issue of VS not showing up the Math box.
- Fixed issue on resolutions of 1024x768 GOverlay would not engage on small resolutions mode.
- Fixed issue restoring GOverlay files was showing the error thatthe feature was not yet enabled when it was.
Re: GOverlay BETA 1.6.4.9
Postby robb » Thu May 24, 2018 2:38 pm
Postby Digidreamer » Fri May 25, 2018 5:54 pm
i'll give it a try
Digidreamer
Postby treborinor » Sat May 26, 2018 4:43 am
Thanks.
treborinor
Postby Habasch » Sat May 26, 2018 4:11 pm
Thx
Habasch
Postby hellrider » Tue May 29, 2018 7:55 am
hellrider
Postby DeLeTe3 » Wed May 30, 2018 2:15 am
(>_<)
DeLeTe3
Postby Mendesic » Wed May 30, 2018 12:04 pm
Morning. I need it, please.
Mendesic
Postby kbal » Wed May 30, 2018 6:00 pm
Kewl.
kbal
Postby tedharris600 » Wed May 30, 2018 8:23 pm
tedharris600
