GOverlay BETA 1.4.2 - Beta #18
Postby TheLaGmAn » Tue Oct 14, 2014 9:34 pm
IMPORTANT: IN ORDER TO RUN UPDATES FROM BETA #18 and NEWER YOU MUST HAVE GOVERLAY BETA #17 RUNNING, YOU CAN NOT UPDATE TO +18 IF GOVERLAY BETA #17 IS NOT INSTALLED ON YOUR SYSTEM, SO DOWNLOAD BETA #17 IF YOU DONT HAVE IT FROM HERE viewtopic.php?f=3&t=56 AND THEN APPLY THIS UPDATE
Version 1.4.1.18 (BETA 1.4.2):
- Test for the new BETA updates.
- BugFix: Plugins not showing up since the last 3 versions should be fixed now.
- Improvement: Now the HDDActivityBox can have a simple design mode which will just show the HDD icon in a smaller size (like the notificationbox hdd activity icon)
Re: GOverlay BETA 1.4.2 - Beta #18
Postby DRA6N » Wed Oct 15, 2014 3:41 am
Nice
DRA6N
Postby Ballantin » Wed Oct 15, 2014 8:46 am
Thank you!
Ballantin
Postby ermethic » Wed Oct 15, 2014 9:51 am
thank you
ermethic
Postby mfilos » Wed Oct 15, 2014 6:56 pm
Nice :D
mfilos
Postby JPYZFR1 » Thu Oct 16, 2014 5:20 pm
Postby yick39 » Thu Oct 16, 2014 11:18 pm
yick39
Postby vinsgosselin » Fri Oct 17, 2014 3:36 am
vinsgosselin
Postby fifacoinhuiy » Fri Oct 17, 2014 5:16 am
:P everything is nice
fifacoinhuiy
Postby mfilos » Fri Oct 17, 2014 10:28 am
TheLaGmAn I have a question.
I completed the "On Windows" profile based to my needs and everything's just fine.
I then exported my profile, and imported it on "While playing" profile (with a new name).
I changed some stuff, in order to put FPS/DirectX sensors and everything saved correctly.
The only problem is that for some reason, while playing (and profile changes based on RTSS) I don't get the new gaming profile, but the stock one (default profile). Of course when I quit the game, the custom "On Windows" profile loads just fine.
Anything wrong I did?
mfilos
