GOverlay BETA 1.6.4.3
Postby TheLaGmAn » Mon Mar 12, 2018 2:24 pm
Version 1.6.4.3:
- Added a new command to GOverlay.exe to load a 3.5 profile, ex: GOverlay.exe -activateprofile3.5 "template - blue (LCD2)"
- Added support for the option of OHM to specify the maximum digits to use for the sensors to apply to the built in OHM support.
- Added support for the "default gaming" profile, so you can create a profile with that name and any game that doesnt have a specific profile will use that one for gaming.
- Fixed issue for WPF applications for RTSS, GOverlay was not detecting them as games running (thanks SubSonix)
- Added option to the ImageBar to be able to pick a specific digit from the sensor to use as the value to draw (so you can use it to draw specific digit numbers)
- Added a new command to GOverlay.exe to load a 2.8 profile, ex: GOverlay.exe -activateprofile2.8 "template - blue (LCD2)"
Re: GOverlay BETA 1.6.4.3
Postby robb » Mon Mar 12, 2018 2:31 pm
Postby Marek » Mon Mar 12, 2018 5:12 pm
thank you
Marek
Postby vrod » Mon Mar 12, 2018 7:04 pm
trying out 2.8
vrod
Postby tedharris600 » Wed Mar 14, 2018 2:14 pm
Thank You
tedharris600
Postby SubSonix » Sat Mar 17, 2018 4:55 pm
SubSonix
Postby Krampas » Sat Mar 17, 2018 5:24 pm
thx
Krampas
Postby DeLeTe3 » Sun Mar 18, 2018 7:30 am
DeLeTe3
Postby JPYZFR1 » Sun Mar 18, 2018 12:38 pm
Postby Racle » Tue Mar 20, 2018 4:05 pm
Thanks! T. Hanks
Racle
Users browsing this forum: No registered users and 23 guests
