GOverlay BETA 1.4.2 - Beta #14
Postby TheLaGmAn » Tue Jul 29, 2014 3:44 pm
Version 1.4.1.14 (BETA 1.4.2):
- Fixed a bug on which some plugins might not work properly
- Fixed some IL2 plugin issues
- Fixed a bug on which after a plugin sensor is no longer required to be used (due to switching from profiles) the plugin sensor was still requested on background
If this fixed the SKYPE issue some users are having please let me know.
Re: GOverlay BETA 1.4.2 - Beta #14
Postby hnbdgr » Tue Jul 29, 2014 4:23 pm
thanks Lagman, will give it a try now!
hnbdgr
Postby jase » Thu Jul 31, 2014 5:20 pm
Thank you.
jase
Postby JPYZFR1 » Thu Jul 31, 2014 5:57 pm
Thanks.
It works fine but skype notifications and splash screen are still not working.
Postby TheLaGmAn » Fri Aug 01, 2014 2:44 pm
About skype, it will be difficult microsoft/skype has dropped API support so its not possible to fetch any more the skype data since its unsupported.
I will keep an eye on it to see what alternatives there are, but its complicated.
Postby heiko » Fri Aug 01, 2014 3:46 pm
Thanks!
heiko
Postby Blackegg13 » Sat Aug 02, 2014 10:15 am
Blackegg13
Postby cyberrage » Sat Aug 02, 2014 1:52 pm
let's try..
cyberrage
Postby Elrynill » Sun Aug 03, 2014 9:41 pm
Version 1.4.2 kept crashing on me, hopefully this one does the job, thanks :)
Elrynill
Postby tedharris600 » Mon Aug 04, 2014 6:49 am
tedharris600
