GOverlay 1.5.4 Released
Postby TheLaGmAn » Wed May 03, 2017 2:02 pm
Version 1.5.4:
- Fixed a memory leak for some windows configurations
- Added crash reporter in the Support tab, a full crash will be generated if GOverlay crashes, in the CrashDumps Folder.
Re: GOverlay 1.5.4 Released
Postby Pupsik » Sun May 14, 2017 8:23 pm
Thank you!
Pupsik
Postby Kabron » Sat May 20, 2017 3:41 pm
Thanks.
Kabron
Postby Raduuu2k7 » Wed May 24, 2017 4:43 pm
Hello,
After updating GOverlay to 1.5.4 (previously I had 1.5.2), the HWInfo plugin has stopped working. There was an error in the log: PluginServices - Error loading plugin HWInfo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null: Public member 'DebugLog' on type 'Form1' not found.
I have made a fresh download of GOverlay 1.5.4 and when I start it up, it does not even display any plugins in the Plugins Menu. Although I have the default plugins in the plugins folder. I am running it as an Administrator.
Any suggestions on how to get the plugins back ?
I am using HWinfo32 ver 5.50, but have also tested with an older version and get the same issue. Win 10.0.14393.
Thanks,
Radu
Raduuu2k7
Postby deNaarling » Thu May 25, 2017 7:01 am
Same here. HWiNFO plugin doesn't work anymore in 1.5.4 Rolling back to 1.5.2 fixes it.
As Raduuu2k17 says.., there are no plugins shown in the Plugins Menu. Though I managed somehow (did this a while ago so can't remember anymore) to let the HWiNFO plugin show up there.
But when I enable the plugin there's only things in the log file happening.
I've attached a file showing what's logged after I start up 1.5.4 and enable the plugin.
Hope this helps restoring the plugins functionality. If I can help in any other way, let me know.
GOverlay HWiNFO log.zip
(2.1 KiB) Downloaded 6884 times
deNaarling
Postby TheLaGmAn » Thu May 25, 2017 3:42 pm
Thanks for the reports. I identified the issue.
Can you check if 1.5.5 works now?
Postby deNaarling » Sat May 27, 2017 5:44 pm
Hi.., I have it working now. GOverlay 1.5.6 in combination with HWiNFO64 5.52(3161)
There is one issue still though, the plugins still don't show up in the Plugins Menu. So after starting GOverlay I'm litterally see nothing listed in there. The logfile only mentions to look for plugins. But doesn't mention an error finding or just finding plugins.
What I've done now to get it working is downloading the HWiNFO plugin from from the topic on this forum and follow the installation instructions that come with it. This still doesn't show any plugin when running GOverlay. Fortunately I still had an old copy of GOverlay 1.4.2 and copied the plugin files from there into the folder of 1.5.6 And so now the HWiNFO plugin shows up. And also now works ofcouse. :) So thank you very much for the quick fix. :)
For your, or other peoples convenience, I'll attach the 2 files I mentioned taking from 1.4.2 which do make the plugin show up in GOverlay for me.
*edit*: Just want to mention that I run GOverlay constantly as administrator.
HWiNfo Plugin Files.zip
(14.75 KiB) Downloaded 6528 times
deNaarling
Postby tyf » Sun May 28, 2017 8:21 am
have the same problem.
did the same thing and it is showin the plugins now.
thanks.
tyf
Postby TheLaGmAn » Sun May 28, 2017 7:22 pm
That is really strange.
So you say that using the current plugin files in 1.5.6 doesnt show any plugin in the list of plugins at all?
Could any of you send me an email to support@goverlay.com with the issue so we do a teamviewer session to check this out?
Postby Raduuu2k7 » Sun May 28, 2017 9:08 pm
I have also tested (1.5.6 with HWInfo32 5.52 ), and now I can properly see the available plugins. I have also tried with a fresh install of 1.5.4 and updated it to 1.5.6 and I can still see the plugins. There was no need to copy them from other versions.
Thanks !
Raduuu2k7
Users browsing this forum: No registered users and 23 guests
