GOverlay BETA 1.4.2
GOverlay BETA 1.4.2
Postby TheLaGmAn » Wed Feb 26, 2014 9:06 pm
Reply to see the link to the current BETA
Version 1.4.2 (BETA):
- Improvement: You can now set how many points the plot graph will have,
so if you have a large graph you can set more points.
- BugFix: Fixed a bug on which in some countries the sensor bar graph, if
the show number option was enabled, the number might have a lot of numbers
if the number was not an integer.
- New Sensor: You now can select the network card to show the IP address
of, integrated with GOverlay without external applications.
- New Feature: You can now select profiles by right clicking on the tray
icon of GOverlay and selecting a profile from the "LCDSys 2.8 Profiles" menu
- BugFix: Fixed an issue in which in some cases the core#1#2#3#4 cpu usage
of OHMDLL was not showing correct values
- BugFix: Fixed an issue in which in some countries the maxdigits option for
sensors was not working right
- Improvement: Now the images uploader shows the calculated real slots the
image will use in the lcdsysinfo memory
- New Feature: Added an option in the GOverlay settings to be able to set
GOverlay to start as administrator
- BugFix: Fixed a bug on which when you selected an element from the list
you were not able to re-select it right away.
- New Feature: You can now set a formatting text in the sensor element, to
add text before and after the sensor value.
- New Feature: You can now set the maximum digits and add leading zeros to
the sensor element.
- New Feature: You can now set the maximum characters to show for the sensor
element.
- New Feature: You can now align the text to left or right in the sensor
element.
- BugFix: Fixed a bug on which the square text would always start with a space
before the text.
- Improvement: Added an option to remove the bar graph border if desired.
Re: GOverlay BETA 1.4.2
Postby rintalahri » Fri Feb 28, 2014 9:35 am
yes..!
rintalahri
Postby joshua » Sat Mar 01, 2014 3:18 pm
thanks!!
joshua
Postby mbartelt » Tue Mar 04, 2014 10:43 am
Thanks for the new beta!
mbartelt
Postby cyberrage » Tue Mar 04, 2014 11:52 am
let's try this beta... release version has a LOT of issue on the ts3 module
cyberrage
Postby TheLaGmAn » Wed Mar 05, 2014 1:50 am
cyberrage wrote:let's try this beta... release version has a LOT of issue on the ts3 module
I got your bug report, i will take a look and let you know, i will probably need a little more info
Postby tedharris600 » Fri Mar 14, 2014 1:33 pm
Thank you.
tedharris600
Postby robertodg » Mon Mar 17, 2014 6:16 pm
GOverlay 1.4.1. use too much RAM.
Windows 7 64bit system 4Gb RAM
Start with 20 Mb and increases rapidly up to 1 Gb.
Then "System.OutOfMemory" generates error and crashes.
robertodg
Postby nemas » Tue Mar 18, 2014 12:00 am
Thanks for this. Runs perfect. :D
nemas
Postby TheLaGmAn » Tue Mar 18, 2014 12:22 pm
robertodg wrote:GOverlay 1.4.1. use too much RAM.
Yes, its a bug with the volume sensor in 1.4.1, 1.4.2beta should work fine
