GOverlay BETA 1.4.2 - Beta #11
Postby TheLaGmAn » Fri Mar 28, 2014 12:29 pm
Version 1.4.2 (BETA):
- BugFix: Fixed a bug to allow HWInfo plugin to work properly
- BugFix: Fixed a bug on TS3 on which your nickname wasnt fetched right in some cases so you would see your nickname speaking instead of "You" when you spoke.
- BugFix: Fixed a bug on TS3 on which you would see your TS-Speaking-Icon enabled when you had your mic muted and you were speaking (but due to mic muted you shouldnt see the mouth light up)
- Improvement: You can now set how many points the plot graph will have,
so if you have a large graph you can set more points.
- BugFix: Fixed a bug on which in some countries the sensor bar graph, if
the show number option was enabled, the number might have a lot of numbers
if the number was not an integer.
- New Sensor: You now can select the network card to show the IP address
of, integrated with GOverlay without external applications.
- New Feature: You can now select profiles by right clicking on the tray
icon of GOverlay and selecting a profile from the "LCDSys 2.8 Profiles" menu
- BugFix: Fixed an issue in which in some cases the core#1#2#3#4 cpu usage
of OHMDLL was not showing correct values
- BugFix: Fixed an issue in which in some countries the maxdigits option for
sensors was not working right
- Improvement: Now the images uploader shows the calculated real slots the
image will use in the lcdsysinfo memory
- New Feature: Added an option in the GOverlay settings to be able to set
GOverlay to start as administrator
- BugFix: Fixed a bug on which when you selected an element from the list
you were not able to re-select it right away.
- New Feature: You can now set a formatting text in the sensor element, to
add text before and after the sensor value.
- New Feature: You can now set the maximum digits and add leading zeros to
the sensor element.
- New Feature: You can now set the maximum characters to show for the sensor
element.
- New Feature: You can now align the text to left or right in the sensor
element.
- BugFix: Fixed a bug on which the square text would always start with a space
before the text.
- Improvement: Added an option to remove the bar graph border if desired.
Re: GOverlay BETA 1.4.2 - Beta #11
Postby dewasha » Sat Mar 29, 2014 1:13 am
dewasha
Postby Dark2do » Sun Mar 30, 2014 10:07 am
Dark2do
Postby cyberrage » Sun Mar 30, 2014 5:33 pm
thx =)
cyberrage
Postby JPYZFR1 » Sun Mar 30, 2014 8:18 pm
Postby mbartelt » Tue Apr 01, 2014 10:20 am
Tanks
mbartelt
Postby azabel86 » Tue Apr 01, 2014 3:21 pm
azabel86
Postby tedharris600 » Tue Apr 01, 2014 11:43 pm
Thanks.
tedharris600
Postby Mike » Thu Apr 03, 2014 11:01 am
Mike
Postby stadtpirat » Sat Apr 05, 2014 10:43 am
stadtpirat
