GOverlay BETA 1.6.9.16 - Release Candidate 3
Re: GOverlay BETA 1.6.9.16 - Release Candidate 3
Postby Hitch_1983 » Thu Nov 25, 2021 9:40 pm
thx
Hitch_1983
Postby ThE-RiP » Fri Dec 10, 2021 5:44 pm
Thank you!
ThE-RiP
Postby WischiWaschi » Sat Dec 11, 2021 11:38 am
Danke
WischiWaschi
Postby Janvolt » Thu Dec 23, 2021 5:57 am
THX
Janvolt
Postby FloteckPower » Sat Dec 25, 2021 10:48 pm
thx
:P
FloteckPower
Postby NikolaiSchlosser » Wed Dec 29, 2021 3:08 pm
TheLaGmAn wrote:Current Changelog:
Version 1.6.9.12:
Upgraded .NET Freamework from 4.0 to 4.5.2 - All GOverlay modules needs to be tested to ensure everything is working as before
Added option to select the frequency of the Latency checks
Implemented LibreHardwareMonitor as a new sensors module (has more sensors than OHM) - Thanks Timm0 for the heads up on this version
Developed new RTSS Hook for 3d overlay and game detection - This needs to be tested to check its working as before
1.6.9.4: Fixed issue with the latency selector
Added missing motherboard sensors to LHM
Fixed an issue on which the color of sensor needle marks of the sensorneedle element would not work, now the selected color applies
Added support for 180 degree roatation of lcdsysinfo2 3.5'' for firmware 241. The devices supporting this feature are the ones with FW 231 that requires a firmware upgrade to 241
Fixed other minor issues
Fixed an issue on which if you tried to use the "upload filetable" button in lcdsysinfo2 but cancelled, it would still try to go thru
Added filetable corruption recognition to display a proper message about it
Added filetable loading error message on the device itself
Fixed an issue with the circle element not allowing to draw a non-filled circle
Added some debug info for VS load
Changed the way it loads VS scripts on startup, no more temporary files
Please leave feedback to ensure everything is working as before
NikolaiSchlosser
Postby Derrick01 » Fri Dec 31, 2021 2:12 pm
Derrick01
Postby snipedown223344 » Fri Dec 31, 2021 2:28 pm
lol
snipedown223344
Postby da_heiko » Sat Jan 01, 2022 12:11 am
da_heiko
Postby Radon222 » Sat Jan 08, 2022 1:11 pm
thx
Radon222
PreviousNext
