GOverlay BETA 1.6.9.16 - Release Candidate 3
Postby TheLaGmAn » Wed Mar 31, 2021 5:39 pm
Version 1.6.9.12:
Upgraded .NET Freamework from 4.0 to 4.5.2 - All GOverlay modules needs to be tested to ensure everything is working as before
Added option to select the frequency of the Latency checks
Implemented LibreHardwareMonitor as a new sensors module (has more sensors than OHM) - Thanks Timm0 for the heads up on this version
Developed new RTSS Hook for 3d overlay and game detection - This needs to be tested to check its working as before
1.6.9.4: Fixed issue with the latency selector
Added missing motherboard sensors to LHM
Fixed an issue on which the color of sensor needle marks of the sensorneedle element would not work, now the selected color applies
Added support for 180 degree roatation of lcdsysinfo2 3.5'' for firmware 241. The devices supporting this feature are the ones with FW 231 that requires a firmware upgrade to 241
Fixed other minor issues
Fixed an issue on which if you tried to use the "upload filetable" button in lcdsysinfo2 but cancelled, it would still try to go thru
Added filetable corruption recognition to display a proper message about it
Added filetable loading error message on the device itself
Fixed an issue with the circle element not allowing to draw a non-filled circle
Added some debug info for VS load
Changed the way it loads VS scripts on startup, no more temporary files
Please leave feedback to ensure everything is working as before
Re: GOverlay BETA 1.6.9.16 - Release Candidate 3
Postby robb » Wed Mar 31, 2021 5:51 pm
Postby RIC9010 » Wed Mar 31, 2021 6:05 pm
Thank you
RIC9010
Postby JaxyL_597 » Wed Mar 31, 2021 9:36 pm
JaxyL_597
Postby tekwar2000 » Thu Apr 01, 2021 3:30 am
tekwar2000
Postby MZman58 » Thu Apr 01, 2021 8:56 am
MZman58
Postby Kingkaktus » Fri Apr 02, 2021 7:09 am
Kingkaktus
Postby Sylvain » Fri Apr 02, 2021 8:06 am
Sylvain
Postby theich » Fri Apr 02, 2021 3:46 pm
theich
Postby nadanomis » Fri Apr 02, 2021 6:10 pm
Bif F**king Thank you!
Your doing great things!
nadanomis
