GOverlay BETA 1.6.9.13 - Release Candidate 2
Postby TheLaGmAn » Tue Feb 09, 2021 3:04 pm
Version 1.6.9.12:
Upgraded .NET Freamework from 4.0 to 4.5.2 - All GOverlay modules needs to be tested to ensure everything is working as before
Added option to select the frequency of the Latency checks
Implemented LibreHardwareMonitor as a new sensors module (has more sensors than OHM) - Thanks Timm0 for the heads up on this version
Developed new RTSS Hook for 3d overlay and game detection - This needs to be tested to check its working as before
1.6.9.4: Fixed issue with the latency selector
Added missing motherboard sensors to LHM
Fixed an issue on which the color of sensor needle marks of the sensorneedle element would not work, now the selected color applies
Added support for 180 degree roatation of lcdsysinfo2 3.5'' for firmware 241. The devices supporting this feature are the ones with FW 231 that requires a firmware upgrade to 241
Fixed other minor issues
Fixed an issue on which if you tried to use the "upload filetable" button in lcdsysinfo2 but cancelled, it would still try to go thru
Added filetable corruption recognition to display a proper message about it
Added filetable loading error message on the device itself
Please leave feedback to ensure everything is working as before
Re: GOverlay BETA 1.6.9.13 - Release Candidate 2
Postby robb » Tue Feb 09, 2021 3:15 pm
Postby 3eas00 » Tue Feb 09, 2021 3:26 pm
3eas00
Postby Dolvic » Wed Feb 10, 2021 10:08 am
Dolvic
Postby Tinkergnome » Wed Feb 10, 2021 11:12 pm
thnx
Tinkergnome
Postby tedharris600 » Thu Feb 11, 2021 1:10 pm
Thank you.
tedharris600
Postby MikeeeMania » Thu Feb 11, 2021 9:27 pm
MikeeeMania
Postby maddog » Fri Feb 12, 2021 6:57 pm
thx
maddog
Postby TheNiele » Fri Feb 12, 2021 9:33 pm
Thank you
TheNiele
Postby xANACONDAx » Sat Feb 13, 2021 12:45 pm
yes i still see 1.6.9. Do you have any idea?
xANACONDAx
