GOverlay BETA 1.6.9.3 - Major internal changes
Postby TheLaGmAn » Sun Feb 09, 2020 6:21 pm
Version 1.6.9.3:
Upgraded .NET Freamework from 4.0 to 4.5.2 - All GOverlay modules needs to be tested to ensure everything is working as before
Added option to select the frequency of the Latency checks
Implemented LibreHardwareMonitor as a new sensors module (has more sensors than OHM) - Thanks Timm0 for the heads up on this version
Developed new RTSS Hook for 3d overlay and game detection - This needs to be tested to check its working as before
1.6.9.4: Fixed issue with the latency selector
Please leave feedback to ensure everything is working as before
Re: GOverlay BETA 1.6.9.3 - Major internal changes
Postby robb » Mon Feb 10, 2020 10:11 am
*edit*
just to let you know when running and enableing the 3.5" screen there is an error in the RTSS_hook2.dll ive taken a screenshot hope that helps
Postby TheLaGmAn » Mon Feb 10, 2020 4:34 pm
can you check that you have the file RTSS_Hook2.dll in your GOverlay folder?
if you have it, can you right click it, properties and see if the file is blocked?
you can use the .exe Old_Goverlay_v169.exe for the moment
Postby robb » Mon Feb 10, 2020 5:37 pm
yes i do have the file in the folder and ive turned secuity off for files comeing from somewhere else and its being run as admin too sorry to be a hassle and thanks i worked out i could use the older version in the folder works fine with that one but just not the new one
Postby TheLaGmAn » Mon Feb 10, 2020 5:43 pm
i think i found the issue, sent you a pm with the missing files, i have added them to the current beta as well
Postby robb » Mon Feb 10, 2020 5:58 pm
tested the new version and that one works thanks for the quick fix
Postby fxsound » Wed Feb 12, 2020 5:11 pm
thnx!
fxsound
Postby dalupus » Thu Feb 13, 2020 11:07 pm
For some reason it doesn't look like the my motherbaord sensors are coming over from Libre Hardware monitor which means I can't display my CPU fan.
Attaching a picture of what I see if I run Libre Hardware Monitor directly.
Pic of what I see in libre hardware monitor.
dalupus
Postby dalupus » Thu Feb 13, 2020 11:09 pm
Also any chance to have it so I can run my own version of Libre Hardware Monitor and have it pick up like it does if I run Open Hardware Monitor directly.
dalupus
Postby TheLaGmAn » Thu Feb 13, 2020 11:55 pm
can you post a list of what you see in GOverlay in the LHM section?
We dont have support for the app, only for the library for now
Users browsing this forum: No registered users and 26 guests
