GOverlay BETA 1.4.3 - Beta #15
Postby TheLaGmAn » Wed Apr 13, 2016 2:36 pm
Version 1.4.2.15 (BETA 1.4.3):
The change from the previous BETA is:
- Fixed issue in the weather not working anymore, now it works again.
- New Feature: Added an option for the regular sensors to have a threshold and a color, when the value of the sensor passes this threshold, the color of the sensor will change to the selected color.
Cumulative changes:
- New Feature: Added "show" argument to GOverlay.exe to make it run visible instead of hidden.
- Fix: Fixed G of GOverlay Header text being clipped when its a BETA.
- New Feature: Added SIV support integrated with GOverlay
- Fix: Fixed RTSS Hook memory leak.
- Fix: Fixed GOverlay_Updater throwing error if the Backup folder did not exist on the GOverlay folder, also due to an issue with the latest compilation of GOverlay 1.4.2, the users who downloaded this version standalone will not be able to auto-update to 1.4.3 due to this error, they need to download the full release or the new GOverlay_Updater.exe
- Fix: Fixed an issue on which if a PlotGraph element was added with display sensor value and the sensor wasnt available on GOverlay first load would throw an error in the LOG.
- Fix: Fixed weather not showing the temperature in the notification bar
Re: GOverlay BETA 1.4.3 - Beta #13 - NEWEST BETA
Postby robb » Wed Apr 13, 2016 3:20 pm
Re: GOverlay BETA 1.4.3 - Beta #15 - NEWEST BETA
Postby JPYZFR1 » Thu Apr 14, 2016 5:02 pm
Postby kbal » Fri Apr 15, 2016 8:17 pm
ql
kbal
Postby SubSonix » Sat Apr 16, 2016 10:45 am
Thank you
SubSonix
Postby triryche » Sun Apr 17, 2016 9:39 pm
Thanks much!
triryche
Postby uli2222 » Mon Apr 18, 2016 11:06 am
Danke
uli2222
Postby Rauma » Tue Apr 19, 2016 4:17 pm
sweet !
Rauma
Postby nieflh » Wed Apr 20, 2016 6:01 am
nieflh
Postby walt » Wed Apr 20, 2016 5:56 pm
walt
