GOverlay BETA 1.4.3 - Beta #10
Postby TheLaGmAn » Thu Feb 04, 2016 1:56 am
Version 1.4.2.10 (BETA 1.4.3):
The change from the previous BETA is:
- Fixed issue in the weather not working anymore, now it works again.
Cumulative changes:
- New Feature: Added "show" argument to GOverlay.exe to make it run visible instead of hidden.
- Fix: Fixed G of GOverlay Header text being clipped when its a BETA.
- New Feature: Added SIV support integrated with GOverlay
- Fix: Fixed RTSS Hook memory leak.
- Fix: Fixed GOverlay_Updater throwing error if the Backup folder did not exist on the GOverlay folder, also due to an issue with the latest compilation of GOverlay 1.4.2, the users who downloaded this version standalone will not be able to auto-update to 1.4.3 due to this error, they need to download the full release or the new GOverlay_Updater.exe
- Fix: Fixed an issue on which if a PlotGraph element was added with display sensor value and the sensor wasnt available on GOverlay first load would throw an error in the LOG.
Re: GOverlay BETA 1.4.3 - Beta #10 - NEWEST BETA
Postby JPYZFR1 » Thu Feb 04, 2016 12:35 pm
Postby robb » Thu Feb 04, 2016 2:29 pm
Postby acolwill » Thu Feb 04, 2016 5:36 pm
Thx
acolwill
Postby gustaftoni » Sat Feb 06, 2016 12:32 pm
Thanks, much appreciated!
EDIT:
One bug for the LCD is you can't export a standard profile and import it back as a 3D profile. It will load but won't be passed to the display. This was true in 1.4.2.8 too.
gustaftoni
Postby Pupsik » Sun Feb 07, 2016 5:41 pm
Pupsik
Postby crainger » Mon Feb 08, 2016 10:33 am
crainger
Postby tedharris600 » Tue Feb 09, 2016 6:10 am
tedharris600
Postby hhl84 » Tue Feb 09, 2016 10:06 am
Yeah. Updates?
hhl84
Postby red-ray » Tue Feb 09, 2016 3:38 pm
Thank you. Did you get my e-mail please?
When I did the update I got a report saying I did not need to update but I did anyway and went from 1.4.2.8 -> 1.4.2.10 :roll:
red-ray
