Weather provider
Weather provider
Postby JPYZFR1 » Sun Feb 01, 2015 5:56 pm
From which weather provider you take info?
Re: Weather provider
Postby TheLaGmAn » Mon Feb 02, 2015 4:05 am
It takes it from yahoo weather, ex feed:
http://xml.weather.yahoo.com/forecastrss?w=2459115
Postby JPYZFR1 » Sat Jan 23, 2016 8:32 pm
Weather and temperature not working anymore. Temperature shows 0.
Postby TheLaGmAn » Sat Jan 23, 2016 9:53 pm
im still getting correct readings of temp, are you sure it wasnt a temporary issue for you?
Postby JPYZFR1 » Sun Jan 24, 2016 9:49 am
24-Jan-16 11:42:05:HDD Got: 7
24-Jan-16 11:42:05:Getting logicaldisk Cat
24-Jan-16 11:42:05:Categories count: 89
24-Jan-16 11:42:04:Getting categories
24-Jan-16 11:41:54:Version detected 1.4.2.8 is the same as 1.4.2 - No need to update
24-Jan-16 11:41:54:Latest version received as: GOverlay_v142.zip (1.4.2)
24-Jan-16 11:41:53:WeatherPull - piraeus,greece : Cant fetch temperature, there is no WOEID
24-Jan-16 11:41:53:WeatherPull - City as >piraeus,greece< not found
24-Jan-16 11:41:53:GOverlay successfully inited
24-Jan-16 11:41:53:Adding power mod events
24-Jan-16 11:41:53:Check Also Device FW Update: 21799805521914110238-117
24-Jan-16 11:41:53:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
24-Jan-16 11:41:53:WeatherPull - piraeus,greece has no WOEID, getting one
24-Jan-16 11:41:53:WeatherPull - investigating: piraeus,greece
24-Jan-16 11:41:53:WeatherPull - Getting weather info
24-Jan-16 11:41:53:Calling WeatherPull
24-Jan-16 11:41:52:LCDSys - Screen clear requested and done
24-Jan-16 11:41:52:Req clear waiting 1
24-Jan-16 11:41:52:counter: Disk Read Bytes/sec
24-Jan-16 11:41:52:instance: C:
I use piraeus,greece for my location and working fine. I don't know what changed and stop working.
i also try
pireas,greece
piraeus,gr
pireas,gr
NewYork, usa
with no result.
Postby TheLaGmAn » Tue Jan 26, 2016 2:09 pm
Seems like the yahoo weather isnt working as it used to.
Try this new version
NOTE: Its always recommended to run GOverlay as Administrator
1. Go to GOverlay and enter in the "Whats New" TAB
2. At the bottom-right, hit on the button "REQUEST BETA"
3. Enter the following CODE
    1.4.2.9_ddc
4. GOverlay will update and you should have this version
Postby JPYZFR1 » Tue Jan 26, 2016 6:45 pm
26-Jan-16 20:40:33:Version detected 1.4.2.9 is the same as 1.4.2 - No need to update
26-Jan-16 20:40:33:Latest version received as: GOverlay_v142.zip (1.4.2)
26-Jan-16 20:40:33:WeatherPull - pireas,greece : Cant fetch temperature, there is no WOEID
26-Jan-16 20:40:33:WeatherPull - City as >pireas,greece< not found
26-Jan-16 20:40:33:GOverlay successfully inited
26-Jan-16 20:40:33:Adding power mod events
26-Jan-16 20:40:33:Check Also Device FW Update: 21799805521914110238-117
26-Jan-16 20:40:33:WeatherPull - pireas,greece has no WOEID, getting one
26-Jan-16 20:40:33:WeatherPull - investigating: pireas,greece
26-Jan-16 20:40:33:WeatherPull - Getting weather info
26-Jan-16 20:40:33:Calling WeatherPull
26-Jan-16 20:42:51:WeatherPull - piraeus,greece : Cant fetch temperature, there is no WOEID
26-Jan-16 20:42:51:WeatherPull - City as >piraeus,greece< not found
26-Jan-16 20:42:51:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
26-Jan-16 20:42:51:WeatherPull - piraeus,greece has no WOEID, getting one
26-Jan-16 20:42:51:WeatherPull - investigating: piraeus,greece
26-Jan-16 20:42:51:WeatherPull - Getting weather info
26-Jan-16 20:42:51:Calling WeatherPull
26-Jan-16 20:46:02:Version detected 1.4.2.9 is the same as 1.4.2 - No need to update
26-Jan-16 20:46:02:Latest version received as: GOverlay_v142.zip (1.4.2)
26-Jan-16 20:46:02:WeatherPull - New York,USA : Cant fetch temperature, there is no WOEID
26-Jan-16 20:46:02:WeatherPull - City as >New York,USA< not found
26-Jan-16 20:46:01:WeatherPull - New York,USA has no WOEID, getting one
26-Jan-16 20:46:01:WeatherPull - investigating: New York,USA
26-Jan-16 20:46:01:WeatherPull - Getting weather info
26-Jan-16 20:46:01:Calling WeatherPull
Still nothing.... :(
Postby TheLaGmAn » Tue Jan 26, 2016 9:24 pm
Odd, its working on mine.
Okay, i added a little more debuging in the log and support to provide a WOEID directly, lets see if this helps
If your location text "pireas,greece" doesnt work try putting "959973" which is the WOID for "pireas,greece".
Also if it doesnt work create a new file named "extensive_log.txt" on the GOverlay folder and run GOverlay again so it has a more descriptive log in case this doesnt work.
Code:
    1.4.2.10_ddf
Postby JPYZFR1 » Tue Jan 26, 2016 10:09 pm
27-Jan-16 00:07:12:GOverlay Started
27-Jan-16 00:07:12:Version: 1.4.2.9
27-Jan-16 00:07:16:WeatherPull - Getting weather info
27-Jan-16 00:07:16:WeatherPull - investigating: 959973
27-Jan-16 00:07:16:WeatherPull - 959973 has no WOEID, getting one
27-Jan-16 00:07:16:Sensor NETActivityBox 1396894763.7624 does not use an advanced skin
27-Jan-16 00:07:16:Check Also Device FW Update: 21799805521914110238-117
27-Jan-16 00:07:16:Adding power mod events
27-Jan-16 00:07:16:GOverlay successfully inited
After update beta still 1.4.2.9 message: (27-Jan-16 00:10:28:Version detected 1.4.2.9 is the same as 1.4.2.10 - No need to update
27-Jan-16 00:10:28:Latest version received as: GOverlay_v14210_ddf.zip (1.4.2.10)
27-Jan-16 00:10:27:Current GOverlay version detected as 1.4.2.9)
log from inside app scrolling and clear and scrolling continiously.
Postby TheLaGmAn » Tue Jan 26, 2016 10:30 pm
Download it manually, the updater isnt recognizing this version
http://www.goverlay.com/UserFiles/GOver ... 10_ddf.zip
