No Temp Reading either in goverlay, AIDA64 or OHWM
Postby 3z4a3 » Sat Jul 20, 2019 9:53 am
Hi !
Just got the 3.5 LCDSysinfo.
Problem is i dont get any Informations exept the usage of my Ryzen 7 2700x.
Tried it with AIDA64 and OHWM. I get every Info i need fine from HWMonitor. I followed every available "fix" i could find on the Internet. Nothing worked for me.
Anyone got a suggestion ?
Greets from Austria
3z4a3
Re: No Temp Reading either in goverlay, AIDA64 or OHWM
Postby TheLaGmAn » Fri Jul 26, 2019 11:29 pm
AIDA doesnt show the sensors you need?
OHM might be too old for a ryzen, thats why it might not show all the data, but AIDA should.
SIV probably should as well, what about HWiNFO?
