Dimm Temps not being picked up in HWinfo
Postby Mage_Mors » Thu Jun 06, 2019 6:32 pm
Hi Goverlay,
I have been trying to put dimm temps on the display. It shows correctly in the hwinfo logging but when I select those fields from hwinfo they show 0 temp when there is a valid hwinfo value. I have the new ram the TridentZ RGB DC double capacity ram. Basically two 16gb sticks of ram on one board. I have 2 channels of memory giving me 64gb total. not sure that has anything to do with it but could you look at it please and see if we can get it fixed. I don't mind loading any beta you need if you dont have this configuration. I think the new DC version of ram is the future.
the hwinfo temperature values you are looking for are labeled Dimm [0] - Dimm [3]
test.CSV
(59.47 KiB) Downloaded 1167 times
Mage_Mors
Re: Dimm Temps not being picked up in HWinfo
Postby TheLaGmAn » Mon Jun 10, 2019 3:22 pm
After you hit save in GOverlay, it still displays zero?
Postby Mage_Mors » Wed Jun 19, 2019 10:22 pm
Yes sorry for being late on response. I was on a vacation :)
yes it still shows 0 after save. Actually the dimm field shows blank then fills in with zero right after save.
Mage_Mors
Postby TheLaGmAn » Wed Jun 19, 2019 11:09 pm
any errors in the goverlay log?
Postby Mage_Mors » Sat Jun 22, 2019 8:16 pm
[HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[0] Temperature:°C]
6/22/2019 1:00:30 PM:-> text : HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[0] Temperature:°C
6/22/2019 1:00:30 PM:-> convertpercent : 0
6/22/2019 1:00:30 PM:-> font_color : 61309
6/22/2019 1:00:30 PM:-> x : 118
6/22/2019 1:00:30 PM:-> type : sensor
6/22/2019 1:00:30 PM:-> maxchars : 0
6/22/2019 1:00:30 PM:-> width : 60
6/22/2019 1:00:30 PM:-> height : 30
6/22/2019 1:00:30 PM:-> t1_color : 61309
6/22/2019 1:00:30 PM:-> font_style : Arial_20px.bin
6/22/2019 1:00:30 PM:-> font_bgtrans : 0
6/22/2019 1:00:30 PM:-> disabled : Enabled
6/22/2019 1:00:30 PM:-> font_transform : 0
6/22/2019 1:00:30 PM:-> index_value : 280
6/22/2019 1:00:30 PM:-> redraw_child : 0
6/22/2019 1:00:30 PM:-> maxdigits : 0
6/22/2019 1:00:30 PM:-> t1_limit :
6/22/2019 1:00:30 PM:-> maxdigits_strict : 0
6/22/2019 1:00:30 PM:save element 1559849166.16664
6/22/2019 1:00:30 PM:-> format : [s]
6/22/2019 1:00:30 PM:-> font_bgcolor : 0
6/22/2019 1:00:30 PM:-> y : 48
6/22/2019 1:00:30 PM:-> font_fixedspacing : 0
6/22/2019 1:00:30 PM:-> font_alignment : -1
6/22/2019 1:00:30 PM:-> sensor_id : [HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[1] Temperature:°C]
6/22/2019 1:00:30 PM:-> text : HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[1] Temperature:°C
6/22/2019 1:00:30 PM:-> x : 17
6/22/2019 1:00:30 PM:-> index_value : 290
6/22/2019 1:00:30 PM:save element 1559848589.76661
6/22/2019 1:00:30 PM:-> y : 216
That is from log file:
PM:Reload LCDSys Mark: [HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[3] Temperature:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [OHMD:/intelcpu/0/load/0]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.6e2fbc6b96ded994ed445c60a04a488b:Memory Clock:MHz]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [OHMD:/nvidiagpu/0/load/0]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [render]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.e4992b332bc5ff0939f3d9d59f2a94b2:GPU Fan0:RPM]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[2] Temperature:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.bc3a282ba6750e876052769a7711cc09:Total CPU Usage:%]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [OHMD:/nvidiagpu/0/temperature/0]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[0] Temperature:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [APP:disk_write__Total]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.1ac8f45347e1f6eef6bdad536df23429:Drive Temperature 2:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [APP:disk_read__Total]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [fps]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [NET:0_down]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [NET:0_up]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM[1] Temperature:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.1ac8f45347e1f6eef6bdad536df23429:Drive Temperature:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.c56676b7c18a10b7e10b47fa4565df60:CPU Package:°C]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [ping]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.4be16c1388f49d629681236955a9d902:AIO Pump:RPM]
6/22/2019 1:08:42 PM:Reload LCDSys Mark: [HW.e4992b332bc5ff0939f3d9d59f2a94b2:GPU Fan1:RPM]
6/22/2019 1:08:42 PM:Network timer (up/down) enabled
6/22/2019 1:08:42 PM:ReloadMarks - Ended
6/22/2019 1:08:42 PM:ReloadMarks - Started
6/22/2019 1:08:42 PM:Reload General (3d-Render) Mark: [time]
6/22/2019 1:08:42 PM:Reload General (3d-Render) Mark: [render]
6/22/2019 1:08:42 PM:Reload General (3d-Render) Mark: [ping]
6/22/2019 1:08:42 PM:Reload General (3d-Render) Mark: [fps]
6/22/2019 1:08:42 PM:Culture Type is: 1
6/22/2019 1:08:42 PM:Reload settings end
6/22/2019 1:08:42 PM:Re-Init LCD
6/22/2019 1:08:42 PM:Profile is Custom (rogfull (LCD2))
6/22/2019 1:08:42 PM:Removing current elements from the window-control
6/22/2019 1:08:42 PM:Done
6/22/2019 1:08:42 PM:All done, task finished
6/22/2019 1:08:42 PM:WeatherPull (Global) - Getting weather info - 0 weathers
6/22/2019 1:08:42 PM:WeatherPull (Global) - Thread ended
6/22/2019 1:08:42 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:42 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
6/22/2019 1:08:42 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
6/22/2019 1:08:42 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature:°C
6/22/2019 1:08:42 PM:LCDSysInfo2 - Clear with color: 0
6/22/2019 1:08:43 PM:LCDSys2 - Screen clear requested and done
6/22/2019 1:08:44 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:44 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
6/22/2019 1:08:44 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
6/22/2019 1:08:44 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature:°C
6/22/2019 1:08:45 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:45 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
6/22/2019 1:08:45 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
6/22/2019 1:08:45 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature:°C
6/22/2019 1:08:46 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:46 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
6/22/2019 1:08:46 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
6/22/2019 1:08:46 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature:°C
6/22/2019 1:08:47 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:47 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
6/22/2019 1:08:47 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM3 Temperature:°C
6/22/2019 1:08:47 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM1 Temperature:°C
6/22/2019 1:08:48 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM2 Temperature:°C
6/22/2019 1:08:48 PM:Missing sensor: HW.5af50dea1fe71ae2b6323ba88efdab72:DIMM0 Temperature:°C
The hwinfo product does update the temps when I look at the sensors live.
Mage_Mors
Postby TheLaGmAn » Sun Jun 23, 2019 12:07 am
can you remove the sensor, save and add it again?
Postby Mage_Mors » Wed Jun 26, 2019 6:42 am
Ya I have done that several times. It doesn't seem to want to read it.
Mage_Mors
Postby Mage_Mors » Sat Jul 13, 2019 9:35 pm
HI still following up. I select the dimm I wanted the temp from in the hwinfo list and it adds the value to the screen I hit save and the value goes right to 0.
I checked hwinfo and the log shows the temps are updating as you can see from the attached. Just trying to provide as much as I can to help get this fixed :)
dimmtemps.csv
HWINFO debug logs.
(1.69 KiB) Downloaded 1186 times
Mage_Mors
Postby TheLaGmAn » Fri Jul 26, 2019 11:26 pm
can you try the beta 1.6.9.2_mel
Postby Mage_Mors » Fri Aug 16, 2019 11:01 pm
Sure how do I get beta ? I tried the request beta in what's new and it says some thing like invalid beta code then closes.
Mage_Mors
Users browsing this forum: No registered users and 32 guests
