Using 3.5 as an extra monitor
Postby TheAlmostCoolDad » Mon Jun 03, 2019 4:01 pm
Hi there, I recently ordered the 3.5 unit and was wondering that if it's in LCD screen mode, does it work like one of those USB monitors? Also, will the GOverlay device work if plugged straight into the motherboard header with a micro USB to header connection?
TheAlmostCoolDad
Re: Using 3.5 as an extra monitor
Postby TheAlmostCoolDad » Fri Jun 07, 2019 7:53 pm
Update for anyone wondering, it does not support being used as an extra monitor. Not sure about plugging into the motherboard yet but I just got some micro USB to motherboard cables to find out. I'll let you folks know!
TheAlmostCoolDad
Postby tasigurl » Wed Jun 03, 2020 10:30 pm
I am definitely interested in your progress here. I want to use mine to mirror my Smartphone screen when I plug it in. Have you tried plugging it into a phone?
tasigurl
Postby TheLaGmAn » Mon Jul 06, 2020 9:21 pm
It cant work as an extra monitor, its a different type of hardware that would be needed for that
Users browsing this forum: No registered users and 40 guests
