Prevents safe removal of USB drive
Postby kbal » Mon Apr 29, 2019 3:42 pm
Safely Remove Hardware fails when GOverlay is running and I try to remove my USB key (also Rufus can't write to USB to create a bootable flash drive).
Event viewer:
The application \Device\HarddiskVolume8\Programs\GOverlay\GOverlay.exe with process id 8612 stopped the removal or ejection for the device USB\VID_13FE&PID_5100\07072457B4D7A635.
kbal
Re: Prevents safe removal of USB drive
Postby TheLaGmAn » Mon Apr 29, 2019 8:09 pm
Thats very strange, is the device connected to the same usb hub root driver?
Maybe try connecting it a different internal usb hub.
GOverlay shouldnt affect other devices disconnection attempts.
Postby kbal » Sun May 05, 2019 8:38 pm
No matter which USB I use.
Win 10 x64
kbal
Users browsing this forum: No registered users and 19 guests
