Changing Output Format
Postby Giveatry » Thu Feb 21, 2019 9:31 pm
Hello, how can you change the output format from MB to MBit or possibly to GB?
Normal is there [s]
Giveatry
Re: Changing Output Format
Postby TheLaGmAn » Fri Feb 22, 2019 2:01 pm
is it for the 3d render, lcdsysinfo2.8 or lcdsysinfo3.5 ?
Postby Giveatry » Sun Feb 24, 2019 1:38 pm
@TheLaGmAn
i used LCDSysInfo 2.5"
Giveatry
Postby TheLaGmAn » Sun Mar 03, 2019 3:49 pm
The only way to do it in 2.8 is by creating a plugin.
In 3.5'' You can also use visual scripting to do it.
Postby Giveatry » Fri Mar 08, 2019 8:11 pm
For a user who has never heard the word "Visual Scripting" it is very difficult to implement.
Is there a description somewhere for using Visual Scripting or maybe a Youtube video explaining the basic principles?
Giveatry
Postby TheLaGmAn » Sat Mar 09, 2019 2:26 pm
We dont have a guide yet, what we have are working examples and a thread for it, i know its not enough but it should help to get started
viewtopic.php?f=2&t=716
Postby Giveatry » Sat Mar 09, 2019 4:08 pm
Thanks, I've already found the thrad but I can't do anything with it. I understand only railway station.
Giveatry
