Blue screen OpenHardwareMonitor Driver
Postby stargate75 » Mon Jan 21, 2019 3:46 pm
Hello i have a problem that i get sometimes a blue screen with goverlay. Its possilbe to disable the "OpenHardwareMonitorLib" because it seems its a problem with the Driver.
stargate75
Re: Blue screen OpenHardwareMonitor Driver
Postby TheLaGmAn » Mon Jan 21, 2019 4:00 pm
Try renaming the openhardwaremonitorlib.dll file to something else, see if GOverlay starts, you should receive a warning.
The other option is to download an older version of openhardwaremonitor
https://openhardwaremonitor.org/downloads/
and try each one of the libs to see if it fixes your crash
Postby stargate75 » Mon Jan 21, 2019 5:01 pm
When i rename openhardwaremonitorlib goverlay crash. And the other versions from openhardwaremonitor have the same error for me
stargate75
Postby TheLaGmAn » Mon Jan 21, 2019 5:57 pm
okay, keep the dll and create a file on the goverlay folder named
disable_ohmdll.txt
see if that works
Postby stargate75 » Mon Jan 21, 2019 7:28 pm
ok openhardwaremonitor is now disabled but i still get the bluescreen and the Kernel dump file still says its Goverlay. Can you send me maybe the version 1.6.6 from goverlay? Bacuse since 1.6.7 i have this problem.
stargate75
Postby TheLaGmAn » Mon Jan 21, 2019 7:30 pm
it would be very weird goverlay povoking a BS.
Here you have 1.6.6:
Postby stargate75 » Mon Jan 21, 2019 7:38 pm
Maybe goverlay have a problem with a other programm or Driver on my pc? I will test now 1.6.6
stargate75
Postby stargate75 » Mon Jan 21, 2019 7:49 pm
ok still have it. but i have test some more stuff when i disable the LCDsysinfo in the Device Manager then it wont crash. Have you maybe a newer Driver for the lcd Display?
stargate75
Postby TheLaGmAn » Mon Jan 21, 2019 11:08 pm
Not really, the driver comes from libusb, you could try a different .sys file
https://sourceforge.net/projects/libusb ... -releases/
but idk if those will actually work okay or not.
Do you have an AV running? maybe its interfering somehow? its very odd for it to bsod
Postby stargate75 » Tue Jan 22, 2019 2:43 pm
Using Kaspersky. Have try to disable but still get the bsod. ok seems to work now with the Driver 1.2.6.0 for now.
stargate75
