X99
X99
Postby Bit_Image » Sat Nov 29, 2014 10:52 pm
My new 5930k CPU does not show all of the items as my old PC did under OpenHardWare.dll, will this be updated soon? Thanks.
Bit_Image
Re: X99
Postby TheLaGmAn » Sun Nov 30, 2014 11:35 pm
Can you check if the OHM App does show it?
http://openhardwaremonitor.org/
Re: X99
Postby stadtpirat » Mon Dec 01, 2014 11:59 pm
I have a X99X Asrock.
You must use Aida64.
If u use Openhardware monitor and u will change the sensor the goverlay crash!
U must delete the complete CPUINFOBox.
U Only can use Aida64.
U cant change the Sensor.
I have a 3770k and change the cpu to 5820k and i dont can change the Sensor, i must delete the complete box.
sorry for my bad englich.
stadtpirat
Re: X99
Postby liveordie » Sat Feb 21, 2015 2:07 am
I use HWiNFO for my X99 OHM is very old and doesn't support X99.
liveordie
Users browsing this forum: Google [Bot] and 1 guest
