Can't Get Weather to Display Correct Temp
Postby JPVann » Sun Jan 20, 2019 3:37 pm
Hi - Wondering if there is a fix to the Weather in your APP? I saw the end of Yahoo API support. Cannot get the correct temp to display for my city.
Is there a fix? Thanks!
JPVann
Re: Can't Get Weather to Display Correct Temp
Postby TheLaGmAn » Sun Jan 20, 2019 9:55 pm
fixed with beta 1.6.7.1
Postby JPVann » Mon Jan 21, 2019 2:09 am
Thanks for your help - all the weather functions work perfectly now!
JPVann
