Using Bar Graph for Volume Percentage Doesn't Work
Postby JPVann » Thu Jan 17, 2019 5:55 pm
When I try to use this my settings are:
Start Height: 1
Steps: 100
Spacing: 1
Max Value: 100
As soon as I set these values the bar graph shrinks to almost nothing but then starts working somewhat. And then disappears when I move the volume not showing any values. Can't figure out what it is doing.
JPVann
Re: Using Bar Graph for Volume Percentage Doesn't Work
Postby TheLaGmAn » Thu Jan 17, 2019 6:33 pm
change the stepping, the steps define how many steps of the bars will be, 100 is too many, put 10 in there (so there will be 10 steps to fill).
Also change the background color, by default its almost black and not noticeable.
I recommend setting a spacing of 3, give it a try.
Users browsing this forum: Bing [Bot] and 33 guests
