CPU TEMP
CPU TEMP
Postby ajpowell » Sun Jan 13, 2019 7:18 am
Help Goverlay not detecting cpu temp ??
ajpowell
Re: CPU TEMP
Postby Amfortas » Thu Feb 13, 2020 3:19 pm
I'd start by going to http://www.goverlay.com/content/faq/ and use the find command to search for CPU.
Amfortas
Re: CPU TEMP
Postby TheLaGmAn » Thu Feb 13, 2020 11:54 pm
if by using the search you cant find cpu temp, GOverlay can also read sensors from other programs like AIDA64, HWiNFO or SIV, or you can try the new GOverlay BETA to see if it appears under "Libre Hardware Monitor", which is a new sensor we are going to support.
viewtopic.php?f=3&t=1594
instructions appear there after replying on how to get it.
