1.6.5??
1.6.5??
Postby nbtc971 » Wed Oct 03, 2018 12:44 am
Why do I have, in 'What's new' this...
Version 1.6.5:
- Added a new command to GOverlay.exe to load a 3.5 profile, ex:
GOverlay.exe -activateprofile3.5 "template - blue (LCD2)"
- Added support for the option of OHM to specify the maximum
digits to use for the sensors to apply to the built in OHM support.
- Added support for the "default gaming" profile, so you can create
a profile with that name and any game that doesnt have a specific
profile will use that one for gaming.
- Fixed issue for WPF applications for RTSS, GOverlay was not
detecting them as games running (thanks SubSonix)
- Added option to the ImageBar to be able to pick a specific digit
from the sensor to use as the value to draw (so you can use it to
draw specific digit numbers)
- Added a new command to GOverlay.exe to load a 2.8 profile, ex:
GOverlay.exe -activateprofile2.8 "template - blue (LCD2)"
- Fixed issue not letting VS add any boxes.
- Fixed issue of VS not showing up the Math box.
- Fixed issue on resolutions of 1024x768 GOverlay would not engage
on small resolutions mode.
- Fixed issue restoring GOverlay files was showing the error that
the feature was not yet enabled when it was.
Yet I don't see that version even in the beta forums? Windows keeps telling me there is a newer version on every boot. I just don't get it. Where is this secret version of the program?
nbtc971
Re: 1.6.5??
Postby TheLaGmAn » Wed Oct 03, 2018 3:49 pm
There is no 1.6.5 yet, it is the cumulative of all the betas for that release. Getting the last one (1.6.4.9) you will get all this
Re: 1.6.5??
Postby nbtc971 » Thu Oct 04, 2018 6:59 am
Ah ok.. will just wait for full release.
nbtc971
